intake ID verify, please
Old Sep 1, 2006 | 08:57 PM
havi's Avatar
havi
I'll have the Roast Duck
Stopped by the local junkyard today. I happened to look under the hood of a 79 supercab f250, and at first glance, I thought I saw a 351M/400 with the big dist. cap and all. But wait a minute, the thermostat housing is different, and the valve covers said powered by ford. the engine sticker is in blue, but isn't readable. I got the intake casting numbers written down, and then I had to move on, since it was closing time. Anyhow, is it worth going back, is the question that remains. Here it is: D1AE-9425-CA the 9 might have been an 8. 0630 was the date tag next to the part number. Firing order is 13726548? so, my instincts tell me it's a W, but hoping it's a C. Any clues?
Old Sep 1, 2006 | 09:25 PM
stryder's Avatar
stryder
My money is on a 351W. With that firing order and a different T-stat housing than a 351M/400, that's sure order for a Windsor. Should be able to get a true ID from the VIN if the engine is original.
Stryder
Old Sep 2, 2006 | 05:33 AM
Torque1st's Avatar
Torque1st
Posting Legend
Frankenstein trucks can be interesting...
Old Sep 2, 2006 | 06:26 AM
2020's Avatar
2020
If the thermostat is in the intake instead of the block,it's a Windsor.
Old Sep 2, 2006 | 06:51 AM
tjc transport's Avatar
tjc transport
i ain't rite
it could also be a 460, or an fe.
but the D1AE tells us it is an intake from a 1971 ford engine.
Old Sep 2, 2006 | 07:50 AM
stryder's Avatar
stryder
The key here is the firing order. FE and 460s have a 1-5-4-2-6-3-7-8 friring order. 351M/400 and 351W have a 1-3-7-2-6-5-4-8. Since he said the T-stat housing is different from the 351M/400, that leaves only the 351W.
Stryder
Old Sep 2, 2006 | 12:37 PM
Mil1ion's Avatar
Mil1ion
That Engine was designed for a 1971 Ford Car that wasn't a Fairlane, Torino,or LTD II
It was cast On *0G30* July 30th /1970
The wet Intake and firing order indicates a Windsor series.
How many valve cover bolts to confirm.
If you have the engine I think you do,it puts out 250 HP@4600 rpm
with 355 ftlbsTq @ 2600 rpm
comp ratio is 9.6
It requires 10* advance timing
finneys98xj
Jan 6, 2011 10:18 PM
axe_handle
Aug 31, 2009 08:07 PM
jd_sylvia
Jan 24, 2005 02:18 PM
Donnie Knight
Nov 17, 2004 12:39 PM
proeliator
Nov 21, 2001 05:48 PM
