yes, i built the truck.the convertor is a stallion 9" with a stall of 4500,rwhp is 575,rwtq is 680.this is with radials on back and letting off 3/4 track( because of alittle breaking up in the higher rpm's)at gainesville raceway.the motor makes well over 650hp at the flywheel and on a dynojet it put down 575.71 rwhp and 680.37 rwtq.the truck currently weighes in at 4200 with driver.oh, the gears are stock 3:50's with a locker.
Truck! Ford truck! I'm guessing you're running a stock suspension? My 60ft was 2.3 seconds... not traction limited sadly. What is a decent drag suspension/setup for a full size truck?
Consistent 12.60s @ 120+Mph. Best TE @ 125.470 with a warmed & massaged early 460, DIVE Block, D3VE Heads in a '79, F-150, Trlr Specl, SWB, under a 66 F-100 CC SWB body with "Built Suspensension" 3.00:1 9" 4 pinion, 10"w X 30"Dia "DOTs". This Truck is "Built" & Massaged for this sort of thing.
