67-72 vs 73-79
Old 09-03-2006, 09:16 PM
scottie2hottie's Avatar
scottie2hottie
scottie2hottie is offline
67-72 contains 4 different front ends, and 73-79 has 3. I think it's hard to compare those broad groups. but thats a different thread :S
Old 09-04-2006, 12:46 PM
Alvin in AZ's Avatar
Alvin in AZ
Alvin in AZ is offline
I guess that depends on what you mean by "different"?
Alvin in AZ
Old 09-04-2006, 08:53 PM
scottie2hottie
Very true....I guess im just too picky i look at each them as different body styles, when even i know that isn't necessarily correct. i definitely look at the '67 diff from the '72 and the '73 diff from the '79. Anyways, i do agree with you. I love '70 front ends. but my alltime fav is '76/'77.
Old 09-16-2006, 09:07 PM
mk's Avatar
mk
mk is offline
Just to clarify what's being said about cab size, I went out and did some measuring on both a 78 and a 68 cab. As the cowl/windshield area is the same from 67-79 I measured from the front of the cowl to the rear of the cab. The 68 is 56 1/2" and the 78 is 58 1/2". I also measured diagonally from the front bottom corner of the cowl to the upper rear top of the back of the roof. This measurement was the same for both cabs so it would appear the two inches added is from the beltline down. The boxes are the same length as well so it appears, scottie, the only adjustment to deal with will be the difference in frame width from the cab back.
mike
Old 09-17-2006, 06:15 AM
jowilker's Avatar
jowilker
jowilker is offline
Mike, Are the floor pans visiable for you to look at and measure? Since the mount points are the same from 65 to 79 and the chassis is 4" longer starting in 73, one must look down in that area to find the changes. Look at the back of the cab and you will see a flat piece welded underneith and adding the additional length to the cab and chassis.
A 65 cab and front clip can be lifted in one piece from the 65 chassis and set on a up to 79 chassis and the 6 mount points should line up and it be bolted down.
John
Old 09-17-2006, 05:27 PM
mk's Avatar
mk
mk is offline
When you say 'four inches longer'', John, are you referring to overall length or wheelbase? All the brochures and info I have tell me the wheelbase for a longbox from 65-66 is 129", 67-72 is 131" and the 73-79 is 133". The rear frame rails are 32" center to center on 67-72 F100s and 34" from 73 on. I guess maybe you're thinking of the difference between your 66 and the 73 wheelbase?
mike
Old 09-17-2006, 08:01 PM
jowilker's Avatar
jowilker
jowilker is offline
Mike the chassis rails are longer starting in 73 and wider to the rear of the rear cab mounts. I didn't know we were addressing wheel base lengths and didn't mention any.
The widening of the rear (under the bed) makes for a wider rear track again making it the same as the front.
sorry
John
Old 09-18-2006, 11:21 AM
mk's Avatar
mk
mk is offline
Wink
Not a big issue. Jes' wanted to make sure we was singin' from the same
page
mike
Old 09-18-2006, 12:28 PM
jowilker's Avatar
jowilker
jowilker is offline
No problem Mike, same page, same hymn book.
John
Old 12-28-2023, 07:26 PM
Orion75's Avatar
Orion75
Orion75 is offline
6th Gear
Originally Posted by jowilker
qman, Ford added 4" to the cab starting in 73. Look in one at the floor pan, it is easy to see, welded to the end of the pan. It was added so that the addition was added to the cab space but did not change the mount points. 65-79 2wd all the same.
FordboyPete says that you can fudge the 4 inches out in an install. I have not done one yet, but I would like to. I have contended that you might have to bob off the ends of the rails. You will also have to adjust the mount points.
Hope this helps a little.
John aka JRW
I am currently restoring my father 77 F250 Custom 2WD. He has passed and I learned to drive on it, so I thought it would be a good project for me and my boys. My cab is in really good shape except the floors. Nobody offers a good replacement, aside from the pans under your feet. But 67-72 offers a full floor replacement. If I am reading your explanation correctly, I should be able to buy the 67-72, and just weld a 4" extension plate after the rear mounts?
Appreciate any input on this subject, as I am not a seasoned body man!!
Old 12-30-2023, 01:10 PM
26tudor's Avatar
26tudor
26tudor is offline
The 67-72 cab will bolt directly to the 77 frame using the original cab mount bolts. That's what I did only I used a f150 frame. you have to move the bed back about 2 inches to center the rear wheels and drill new hole to mount the bed.
Old 01-13-2024, 04:18 AM
Notgoday2740's Avatar
Notgoday2740
Notgoday2740 is offline
6th Gear
I don't know which page I was on or or which form I was in before where there was conversation about the bezel for the 67 headlamp or headlights
I need a left-sided one and hoping to pay no more than around
$50
TI,
MAREN
  #28
Old 02-02-2024, 07:22 PM
Orion75's Avatar
Orion75
Orion75 is offline
6th Gear
Thank you for the information. Yes, I realize the 67-72 cab will bolt directly to the 77 frame. That is the reason for my question. I cannot get a 72-79 floor pan assembly. But I can get a 67-72 floor pan assembly. Seeing as they bolt up the same, and the extra is apparently added behind the rear cab bolts, I was curious if anyone knew for sure that the rest is dimensionally the same? Meaning, I could buy the 67 floor pan assembly, weld it under my 77 cab, and just add an extension behind the rear mount bolts. I'm not sure if there are other considerations as to why it may not work?
itsabullitt
WTB - Parts & other
23
01-14-2017 11:55 PM
PetesPonies
11-08-2015 07:15 PM
Sam's1967
06-15-2015 12:59 PM
havi
08-19-2010 04:35 PM
wintremute
04-17-2006 03:12 PM
Quick Reply: 67-72 vs 73-79
