Axle width and hood width question
Old Aug 11, 2010 | 07:13 PM
havi's Avatar
havi
I'll have the Roast Duck
Just curious, but I have a question on axles. I know the '73-79 axles are like 5" wider or so. However, if the '67-72 front clips and cabs fit over a '73-79 chassis, where is the width difference made up? Is the wheel tucked under the '67-72 fender more, or is the '67-72 hood & cab not as wide as '73-79?
Old Aug 12, 2010 | 10:17 AM
jackslater's Avatar
jackslater
I believe the difference in axle width is only on the order of a couple of inches. Someone may come along here and give exact specs.
This means the tires on the newer truck stick out about an inch further on each side.
Old Aug 12, 2010 | 04:17 PM
havi's Avatar
havi
Thanks for the reply, and you're right about my concern for wheels sticking out too far. I'm looking to replace my '79 Bronco tub with a bumpside, and I'm trying to make it look period correct as possible. Tires sticking out too far would not be period correct.
Old Aug 18, 2010 | 08:41 PM
havi's Avatar
havi
Can anyone provide the width for the hood?
Old Aug 18, 2010 | 11:53 PM
frankensteined_67's Avatar
frankensteined_67
the front axle is the same width as the 67-72. the difference in width is in the rear end. the 67-72 is a few inches narrower the the 73-79. the front end of the 67-72 is the same width as the 73-79 axle and body.
Old Aug 19, 2010 | 09:54 AM
havi's Avatar
havi
That's what I thought, but wasn't sure. Makes sense if the body mounts are the same. Thanks Randy. So all I have to do now, is find a bumpside body and bed, since I already have a rear axle from '68.
Old Aug 19, 2010 | 04:35 PM
havi's Avatar
havi
I also have a '76 F250 front axle. So it seems possible that a late 70's F250 axle with the disc brakes would bolt up under a '67-72 F250. I know most years, and have owned quite a few, but the '67-72 is one generation I haven't had...... yet.
1985 Bronco
Mar 3, 2017 02:07 PM
stubbfarmer
Jan 6, 2017 06:59 PM
PetesPonies
Nov 8, 2015 07:15 PM
Jaysouth2000
Aug 29, 2004 08:53 AM
6677ebman
Aug 13, 2003 11:14 PM
