Aerostar Ford Aerostar
intermittant ABS light
Old Aug 31, 2006 | 12:42 AM
BCMike's Avatar
BCMike
My '95 AWD XLT automatic Aerostar has started to exhibit this problem. The ABS seems to come on and off intermittantly and what appears to be randomly. Anyone have a clue what might be going on?
Old Sep 2, 2006 | 11:06 PM
xlt4wd90's Avatar
xlt4wd90
There are a couple of simple things to check:
1. Brakes lights - make sure Both bulbs are working.
2. Brake fluid level - make sure the reservoir on the master cylinder is full.
3. Shuttle valve switch on master cylinder - This switch is screwed into the front of the MC, and the hole it goes into can collect moisture. The resulting corrosion byproducts can short out the switch, causing brake warning lights to come on. Pull the switch and check with a flashlight. Clean out any gunk you find in there.
Old Sep 3, 2006 | 12:42 AM
BCMike's Avatar
BCMike
Thanks for the tips, Ill check those out. I just swapped out the PS pump. I might have knocked that shuttle valve switch you mention. It's been a coon's age since I checked the brake fluid level. I had a chance to follow it for a couple blocks the other day and all the brake lights are working.
Old Sep 3, 2006 | 06:22 AM
96_4wdr's Avatar
96_4wdr
also, may be air or water in the brakes....how long since a complete fluid change and bleed?
Old Sep 3, 2006 | 09:47 AM
Pablo-UA's Avatar
Pablo-UA
I have no ABS, but i use to repare WABCO abs on trucks... Usually abs light if connectors on wheel speed sensors are bad and loose contyact periodically....
drdave
1997 - 2003 F150
Jan 19, 2011 12:15 PM
senix
6.4L Power Stroke Diesel
Feb 12, 2010 02:59 PM
rett8799
Mar 13, 2007 07:53 PM
rett8799
1997 - 2003 F150
Jan 20, 2005 12:35 PM
swunderle
Escape & Escape Hybrid
Nov 7, 2004 03:59 PM
