Sponsored by: Auxito
ABS light?
Old Jan 18, 2005 | 07:41 PM
rett8799's Avatar
rett8799
Question ABS light?
I got an intermittent ABS light and the brake pedal jumps once in awhile!
Any suggestion?
Old Jan 19, 2005 | 08:18 AM
projectSHO89's Avatar
projectSHO89
Identify your vehicle so it can be researched.
Otherwise, it can only be said that you have an intermittent fault in the ABS system (DUH!!).
You will likely need to pull the ABS codes so you know where to focus diagnostic efforts. The procedure varies by year.
Steve
Old Jan 19, 2005 | 08:23 AM
rett8799's Avatar
rett8799
99 F150 4.2L 4x2
Old Jan 20, 2005 | 08:36 AM
projectSHO89
Unfortuanately, I don't have a 99 service CD.
However, on the 2000 CD, it has different procedures for extracting codes from the ABS computer depending on whether your systemm is rear-only (RABS) or 4-wheel ABS. The RABS system DTCs can be extracted without the scan tool but the 4-wheel version requires the scan tool.
The 99 is likely similar.
From looking over the diagnostic procedures, it's likely you have an intermittent wheel or differential sensor that is causing the ABS system to activate at the wrong time. It might also be an intermittent wiring problem to one of the sensors.
Steve
Old Jan 20, 2005 | 12:35 PM
MrBSS's Avatar
MrBSS
Yes, without scan tools, the first thing is to check and clean the sensors and connections. Any that look bad, probably are. Next thing is to fully bleed the brakes (which you should be doing periodically anyway). I'm not sure if the basic scan tools will find ABS problems, but if they claim to, now might be the time to get one.
Obviously, the value of your time and cost of "guessed wrong" parts may soon exceed the cost of having it diagnosed by someone who's done this before.
Diesel_Brad
Oct 7, 2012 08:59 AM
BillU05
1997 - 2003 F150
16
Sep 6, 2005 12:25 PM
swunderle
Escape & Escape Hybrid
Nov 7, 2004 03:59 PM
RobertGordon
Mar 6, 2004 08:22 PM
garymulins
1978 - 1996 Big Bronco
15
Nov 30, 2002 10:38 PM
