Sponsored by: Auxito
ABS light issue
Old Dec 19, 2010 | 04:30 PM
drdave's Avatar
drdave
ABS light issue
My 2002 has recently (in the last two months) started having the ABS light come on intermittantly. I removed and cleaned both front ABS sensors (they were very dirty) and also the rear sensor (not very dirty). It did not correct the issue. What is my next course of action?
Old Dec 19, 2010 | 10:40 PM
Dave G.'s Avatar
Dave G.
How are the sensor rings on the front rotors ? Caked with dirt or rust build up, or, missing a tooth or more, can cause signals to be inconsistent. Could be the sensor bracket got bent a little from repairs or rocks or something. If the air gap isn't the same on both fronts, the signal will be faulty. It's also possible that a corroded harness connection is blocking a signal.
Dave
Old Dec 20, 2010 | 07:16 AM
drdave's Avatar
drdave
The front sensor rings did look a little dirty but I did not clean them. How do you get the sensor gap set and what should the measurement be? Will there be a fault code to point to the problem?
Old Dec 20, 2010 | 08:08 AM
Dave G.'s Avatar
Dave G.
If the sensor mounting bracket isn't bent, the air gap isn't adjustable as far as I know. Also, the air gap is usually something like .045-.050. Hard to measure with rust and corrosion. The sensor is magnetic, so if the sensor ring is nasty with rust, dirt, or missing teeth, the AC signal will be erratic. There might be a code for signal strength, but unless the sensor fails, it may not be a hard fault code. Yours seems to be still functional to some degree, that's why I suspect sensor ring problem, or, possibly a harness wire/connection issue.
You can check the sensors for signal, but it's not really easy. The wire leads can be checked with an AC voltmeter ( the leads from the sensor itself ), if you can make that connection, and with help, spin the wheel. You need around 5 mph speed equivalent or greater for the sensor to produce a signal. Something just short of 1 v AC, I think is minimum.
Dave
Old Jan 19, 2011 | 10:51 AM
drdave's Avatar
drdave
I finally had the ABS system scanned for codes and the right front sensor showed up as bad. I bought a new sensor and replaced it. It was obvious what was wrong with it once removed. The wire had fallen off the inner fender and was touching the exhaust manifold where it sustained some melting and damage. I also cleaned the sensor ring before installing the new sensor. A scan the next day did not reveal any ABS codes present. Hopefully this issue is resolved.
Old Jan 19, 2011 | 12:15 PM
Dave G.'s Avatar
Dave G.
Glad you repaired it. Just in time too, especially if the snow keeps moving south ! The ABS will be real handy.
Dave
buckeyes8603
Feb 28, 2011 06:56 AM
02f350gurl
Dec 16, 2010 07:36 PM
351whitewindsor
Aug 9, 2009 11:21 PM
lilbilli0naire
13
Jan 26, 2008 06:44 PM
rcarroll
Sep 8, 2004 03:11 PM
