Brake rumble?
Old Aug 30, 2006 | 12:32 PM
Shaman's Avatar
Shaman
Brake rumble?
Hi guys,
When I apply the brakes to my '90 Ranger, I hear and feel a deep rumbling sound from the back.
Is this a classic symptom of a warped disc?
I know one should not assume anything, but I would like to arm myself with some knowledge before I take her in to a mechanic so I won't get screwed.
Thank you for your time,
--Skip
Old Aug 30, 2006 | 01:41 PM
matt's2.9STX's Avatar
matt's2.9STX
Rangers run drums on the back, but it's very likely something out of true with the brakes. There are a couple other issues that can seem like that, but you can usually narrow it down yourself by paying attention to what it seems to do & under what you're trying to do with it. Sounds like you've done that. You're probably looking at a new drum soon. Hope it's cheap.
Old Aug 30, 2006 | 04:26 PM
CBFryman's Avatar
CBFryman
It may be an over worn drum lining that is now goughing grooves into your drum...happened on my passenger side disk and it sounds like a grumbleing.
Old Aug 30, 2006 | 05:20 PM
Shaman's Avatar
Shaman
Thanks guys...The plot thickens!......Today at a stoplight some fool pulled out in front of me and I had to slam on my brakes.
The left rear brake apparently hung up for a few moments, because I could feel it tug for about a half-block, and then I felt it release.
When I arrived at work, the left rear rim was hot and the rest of the wheels were not hot.
So I know that means some kind of brake job, but please tell me what exactly happend here?
Thanks,
Skip
Old Aug 30, 2006 | 05:47 PM
RangerPilot's Avatar
RangerPilot
Seems like the brake is hanging under all conditions, that's what makes the rim abnormally hot.
04X
Oct 19, 2017 03:31 PM
Biggg72
Feb 7, 2011 10:55 AM
CurtisLoew
General Automotive Discussion
15
Dec 7, 2007 11:32 AM
61Canuck
48
Mar 20, 2007 12:02 AM
mlisi585
1997 - 2003 F150
Apr 29, 2005 04:49 PM
