Sponsored by: Auxito
Rear End rumble
Old Apr 24, 2005 | 09:42 PM
mlisi585's Avatar
mlisi585
Unhappy Rear End rumble
My 2002 f150 FX4, recently developed a kind of rumbling noise with vibration on deceleration,
In the cab it sounds like I have large mud tires on the back,or am driving on a mild rumble strip or have an exhaust leak, but only during deceleration, I checked the brakes, tires and exhaust all seam fine it doesnt seem to effect the transmission or motor, I have heard of possible problems with the clutches in the FX4s rear end, I and am looking for any leads to fixing this problem. Any suggestions or ideas are greatly appreciated.
Old Apr 24, 2005 | 10:19 PM
psdiesel's Avatar
psdiesel
Hi with out driving your truck can't say what your problem is.But the clutches in the limited slip rear are not the cause, if the noise is when you are not turning.
Old Apr 24, 2005 | 11:53 PM
LxMan1's Avatar
LxMan1
Sounds like the gears have improper backlash. Check to make sure that the pinion nut isn't working loose.
Old Apr 25, 2005 | 08:04 PM
keporter's Avatar
keporter
My rear-end clutches only make noise while turning. Replaced by dealer 3000 miles ago and already back to rumbling. Hope they can eventually get it right. I'm almost out of warranty.
Question to the experts as I am not one. The rearend was fine until this past winter and I used the 4x4, right afterwards, with-in a 100 miles the clutches went out. Had them replaced, used 4x4 to get up a driveway that was 1inches deep of sticky mud, upon disengaging 4x4, the clutch rumble is back and getting worse. I only engage it when stopped so it can't be that I was going to fast. Any suggestions, or is the FX4 4x4 not really supposed to be used!!!!!
Kevin
Old Apr 29, 2005 | 04:49 PM
mlisi585's Avatar
mlisi585
problem
The problem turned out to be, a frozen rear end U-joint. Everything works great now!!! Hope this helps someone. It would be too much of an expense for ford motor company to put grease joints in immediately. Thanks for the tries!
jspringator
Jan 6, 2016 06:59 AM
SloSupra
May 2, 2015 10:19 AM
jer6666
2004 - 2008 F150
Apr 22, 2015 12:21 PM
jspringator
Nov 3, 2011 02:54 PM
patsplace
Exhaust Systems
Dec 31, 2002 10:45 AM
