7.3 nostart
Aug 30, 2006 | 11:18 AM
7.3 nostart
every once in a while the truck won't crank on the first try (in P) and then has to be put in N before cranking... Anyone heard of this?
WB
Aug 30, 2006 | 04:23 PM
What happens when you turn the key to crank while in Park?
Aug 30, 2006 | 04:26 PM
It cranks, but wont fire.
Aug 30, 2006 | 04:45 PM
Does trying it in neutral solve the problem EVERY time? I'd have said CPS first off if you hadn't mentioned the neutral thing. Still could be CPS...
How long has it been going on?
Aug 30, 2006 | 05:00 PM
month or so... I have replaced the CPS (blue) before when the truck was stalling out (last April).
Yeah neutral has been sure fire... can't think of a single time it hasn't fired in N.
Aug 30, 2006 | 05:36 PM
I can only think of Neutral Safety Switch but I don't really don't know.
I hope some other folks can stop by and offer their thoughts.
Aug 30, 2006 | 05:46 PM
Thanks for the attempt...
I am kinda stumped too
Sep 1, 2006 | 03:21 PM
so nobody else has any input?
could it be something to do with the wiring near for the tranny? I got a TC locker switch, could it be that? or a wire near it outta whack?
Sep 1, 2006 | 10:16 PM
Maybe the neutral safety switch is all I can think of.
OT here, but did you figure out how long the hose needed to be for your homemade HPX? I haven't had time to open the hood on mine.
Sep 1, 2006 | 10:30 PM
Hey this might be dumb but it happened to me , I had 1 bad battery ...the truck would crank ,a little slow but it turned over, wouldnt fire ... if the voltagle is too low in 1 battery that starter wont crank fast enough.
Sep 3, 2006 | 04:06 PM
swapped both batteries this morning.... I can tell a very big difference in the sound of the crank... faster and higher pitched.
So far so good... we will see how this turns out... hope it works
Andysutt
15
May 19, 2003 05:22 PM
karljay
Aug 20, 2002 07:36 PM
jaye
May 9, 2002 11:32 PM
earthworms
Mar 28, 2001 11:19 AM
charles_1
Jan 11, 2000 09:46 PM
