wants to start
Old Aug 28, 2006 | 01:40 PM
padrinho's Avatar
padrinho
wants to start
ignition is in the off position and the truck is trying to start
77 f-150 4.9 300 v6
Old Aug 28, 2006 | 02:11 PM
1975Ford's Avatar
1975Ford
If you haven't messed with any of the electrical wires, then replace the starter.
Old Aug 28, 2006 | 02:25 PM
9thPony's Avatar
9thPony
Sounds like a bad ignition switch to me. Could also be the solenoid, or improper wiring at the solenoid.
I would not think it was the starter as it should only be able to get power through the solenoid, and if everything was working right only when you turn the key
Doug
Old Aug 28, 2006 | 04:11 PM
Mil1ion's Avatar
Mil1ion
Disconnect the wire plug on the S terminal and see if it still tries to start.
with the key off .....check for power at the S terminal plug that you just removed.
Or
It maybe be a Bad solenoid or faulty ignition switch
Old Aug 28, 2006 | 05:32 PM
1975Ford's Avatar
1975Ford
It seems like the solenoid on the starter is pitted and sticking.
B1GKAHUNA
Jun 15, 2014 02:05 PM
equine_21
Jan 15, 2003 04:14 PM
Redneckerson
Mar 15, 2002 07:49 PM
mrshorty
Feb 28, 2002 04:18 PM
Pastmaster
Dec 4, 2001 04:36 PM
