turning crank.
Old Aug 21, 2006 | 01:16 PM
76JDGREEN's Avatar
76JDGREEN
turning crank.
I dropped a 71' 460 in a 76' high boy andnow the crank wont turn by hand. what do i need to do?
Old Aug 21, 2006 | 02:06 PM
Mil1ion's Avatar
Mil1ion
Put the transmission in neutral
What is hooked up to the engine ?
Btw this would have been better placed in the general automotive discussion forum.
It has nothing to do with 73-79 truck.
Old Aug 21, 2006 | 06:17 PM
76JDGREEN's Avatar
76JDGREEN
Talking
well I'm doing a 351 to 460 conversion in my 1976 f-250 4x4. The engine was from a 71 ford car and is in the truck now, but I cant turn the crank by hand. My trucks year may be beneficial as somebody may have done this conversion and been in the same situation and probably would be in 73-79 truck which happens to be what my truck is. The question I had is why do you think my crank wont turn?
Old Aug 21, 2006 | 07:44 PM
STGFordCrazy04's Avatar
STGFordCrazy04
did you check the main and rod bearings for correct size? I JUST (as in 5 days ago) had this problem and had to pull the motor because of a PO wasnt careful. The 385 series forum is great for 460 problems. Monsterbaby aka Rob and many others are extremely helpful. He mentioned other problems that may cause a tight motor are timing too far advanced and wrong valve springs for the cam.
mjtpolice76
Apr 5, 2014 07:54 PM
76xltcc
Aug 8, 2012 11:16 PM
76JDGREEN
Engine Swaps
Aug 23, 2006 09:26 PM
76JDGREEN
15
Aug 23, 2006 07:33 PM
fordguy76
33
Jul 26, 2002 09:20 AM
