need help no start
Old Apr 5, 2014 | 03:08 PM
mjtpolice76's Avatar
mjtpolice76
need help no start
truck started fine this morning went to move it couple hours later won't start. It just cranks an cranks not even a chug out of the motor. Glowplugs are energized oil level is good oil is clean, fuel in the fuel bowl fuel pump kicks on when i turn the key. No smoke when cranking coming out the tail pipe. Im thinking CPS? But what else should I look at?
Old Apr 5, 2014 | 03:25 PM
Pikachu's Avatar
Pikachu
Does the wait to start light come on? If not, check your fuses. If a 30A fuse is blown, unplug the fuel heater plug on the fuel bowl, replace the fuse and see if it starts.
Old Apr 5, 2014 | 07:12 PM
mjtpolice76
Wait to start light does come on
Old Apr 5, 2014 | 07:54 PM
Pikachu's Avatar
Pikachu
It certainly could be CPS. It could be several other things too, though. Do you have any way to monitor ICP and IPR duty cycle while trying to start, like AE or Torque Pro? If not, you could try disconnecting the ICP sensor and seeing if it will start that way. Where are you located? Maybe someone is nearby and wouldn't mind giving you a hand figuring it out.
dmcgann
15
Jan 2, 2015 01:36 PM
BLK 96
Jan 9, 2013 10:11 PM
forhammer33
Apr 4, 2012 08:03 PM
Lady1989
13
Oct 5, 2011 07:33 PM
FoxNotch
22
Feb 27, 2010 06:21 PM
