Sponsored by: Auxito
torsion bar question
Old Aug 12, 2006 | 07:37 PM
kmt2006's Avatar
kmt2006
Can I crank up my torsion bars about a inch to level the front of the truck with the back without having to replace shocks and would it really affect the ride?
Thanks
Old Aug 12, 2006 | 07:42 PM
97Handshaker's Avatar
97Handshaker
Yes, you can crank them. just not more than 2 inches. because it will mess up your cv angles really bad. The ride might be a lil more stiff.
Old Aug 12, 2006 | 11:18 PM
fordman311's Avatar
fordman311
Ride will suffer a little. Just an inch it wont be too bad. Dont need new shocks. You might be raising the front end up but you arent giving it any more articulation. For example (just random numbers) say on a stock suspension the tires can move up 5 inches and down 5 inches. By cranking the bars one way or another you can change it to up 7 and down 3 inches. Or up 3 and down 7 inches. Those numbers have no basis in reality, just tryna give you an idea. I always use more words than necessary. Hope i didnt just confuse you more.
Old Aug 13, 2006 | 08:45 AM
Humphrey99's Avatar
Humphrey99
Did it to mine. I think it really improves the stance. The ride is a little stiffer but it's a truck right? Don't forget to take it to the alignment shop.
Old Aug 13, 2006 | 09:37 AM
captain p4's Avatar
captain p4
What these guys said:
Ride will be a -little- stiffer, but you probably won't even notice
Take it to get aligned afterwords
No shocks needed
don't go more than 1.5 inches or you'll have problems with the angles.
rmroost
Dec 15, 2004 07:24 PM
rmroost
Offroad & 4x4
Oct 8, 2004 11:46 AM
nwtfox
1997 - 2003 F150
Dec 10, 2003 09:50 PM
sly
1983 - 2012 Ranger & B-Series
Nov 22, 2002 06:45 PM
