Sponsored by: Auxito
Torsion Bars
Old Dec 9, 2003 | 02:13 PM
nwtfox's Avatar
nwtfox
Torsion Bars
How many turns can I get out of my torsion bars before I will have to worry about getting the truck realigned?
Old Dec 9, 2003 | 06:47 PM
umdstang's Avatar
umdstang
Hi and welcome to FTE
it is a hit or miss thing i wouldnt turn them all the way
Brian
Old Dec 10, 2003 | 12:41 AM
Racerguy's Avatar
Racerguy
Hi nwtfox and welcome to FTE
If you go by the book, anytime you change the ride height of a vehicle you should get the alignment checked. Realistically you can probably jack a few turns into it without changing the alignment. Like Brian said, cranking them up the whole way isnt a good idea.
Old Dec 10, 2003 | 02:57 AM
tobydanr's Avatar
tobydanr
I had a GMC Sanoma 95, it had torsion bars on the front. the front drive universal joints started banging when I jacked it up.
Old Dec 10, 2003 | 07:52 AM
nwtfox's Avatar
nwtfox
I have heard some guys are getting four to five turns? Anybody try any of these?
Old Dec 10, 2003 | 10:46 AM
Rusty1's Avatar
Rusty1
From my experience with adjusting the "T" bars, if your trying to level the truck out, that's enough to have to get the front end aligned.
It's not that you'll go veering off the road if you don't align it. The only thing is your tires will wear out .
My suggestion is, if you can avoid tightening the "T" bars you should, the ride is terrible. You may look cool but...
Old Dec 10, 2003 | 09:14 PM
aldridgec's Avatar
aldridgec
NWT Fox, yeah, you could get 8 turns out of them. But i've put mine back down some since I leveled my 7700. The ride was alittle bouncy as it ran out of down travel. With it lowered back some its seems to be better.
Old Dec 10, 2003 | 09:50 PM
CPerry's Avatar
CPerry
I got mine turned 4 times. It is not quite level but it is close. I can notice a slight difference in handling and have not had the alingment checked. When I buy new tires, I will have it checked then.
jason gressley
1997 - 2003 F150
Jun 4, 2005 10:23 AM
smplfrk
1983 - 2012 Ranger & B-Series
Mar 16, 2005 12:50 AM
rmroost
Dec 15, 2004 07:24 PM
DRP
1997 - 2003 F150
Aug 19, 2004 11:58 PM
