I am having a problem with my 1996 Explorer with 155K miles on it. Whenever the suspension moves at all (turns, bumps, etc.) there is this awful squeaking noise that comes from the front passenger side. I am not all that car savvy but have reason to believe it is the ball joints on that side. Questions:
1. Is this something that it is necessary to fix i.e. are there some saftey concerns we're dealing with here or is is something that is just annoying.
2. Will simply spraying some sort of lubricant from time to time be an adequate fix?
3. Does this sound like a ball joint problem even?
4. What is a fair price for parts and labor to get this repaired? I have been quoted $600-800. Is this reasonable? I would try and fix it myself but don't have enough time....
its very easy to replace the upper joint on the pass. side since its a two piece design. I think it took me less then 1 hour total time to do mine. You just unbolt a few bolts and the middle piece pops off. I had to pay $150 for a moog joint becuase napa was out of the napa brand $40 part.
CDNSoldier has a point but just to help you out.. look at the arms that come off the frame to hold your brakes on.. they are the control arms the balljoint is the joint that connects the arms to the brakes (well the front hub/knuckle actually) pretty easy to spot even with the wheel still on.
Usually it's a tie rod end causing that squeaking noise, but at 155K anything's possible!
It's also likely that all 4 ball joints are bad at that mileage... and if they are all original i can GUARANTEE they are all bad.
Jack up the car under the lower control arm just far enough to lift the tire off the ground about 3/4". Push in and out at the very top of the wheel.. if any play exists, it's most likely upper ball joint play.. but also possible control arm bushings or wheel bearing...
Now push and pull at the left and right sides of the wheel (like turning left and right)... if any play is felt it's likely tie rod end play.. but also possible wheel bearing play..
Now pry up on the tire from the bottom with a pry bar. It's easiest to have someone do this while you observe the lower ball joint. If you see the knuckle moving up and down on the ball joint you have play in it.
Ford "allows" up to .030" (thirty thousandths of an inch) of play in ball joints, but in my opinion any play at all warrants replacement.
would it be dangerous not to replace this? I'm not sure if I can afford this right now and don't think I'm savvy enough to fix this on my own. Is this a saftey hazard or just an annoyance? Because I can put up with the squeaking until I can afford the operation....I just don't want to crash in the meantime
