Front End Squeak
Old Dec 7, 2011 | 09:31 AM
Eastland's Avatar
Eastland
Front End Squeak
I am almost certain that the noise is from the ball joints but wanted to make sure. I get a fairly loud squeaking sound form the front drivers side tire area at low speeds and when turning and I know that the ball joints are bad. Is this most likely the ball joints and should go away once I replace them, already have the new XRF parts and hope to do that this weekend along with the pads, rotors and new warn hubs as well.
Also other than tire damage, what am i risking driving it with the bad ball joints?
Thanks,
Old Dec 7, 2011 | 12:09 PM
jasonodsky's Avatar
jasonodsky
There is the slight possibility the squeaking ball joint can completely fail and the front wheel falls inward. I don't think that'll be likely in the next week. I drove a few thousand miles with the squeaking ball joint before I replaced it. The upper drivers side was physically loose, I could wiggle it about 1/4" when I pulled it out to replace it.
Old Dec 7, 2011 | 01:43 PM
TXtinct's Avatar
TXtinct
You'll shoot your eye out
Before you spent all that money make sure it's not this guy...
crazytwo
Jan 15, 2015 12:50 PM
DieselCamper01
Aug 15, 2008 07:56 AM
SDTruckMan
May 2, 2007 06:56 AM
MattsExcursion
Oct 4, 2006 05:13 PM
fowlerford56
Sep 9, 2004 09:00 AM
