Keyless Keypad Code
Old Oct 23, 2006 | 10:14 PM
  #61
exposition's Avatar
exposition
OOps'forgot to give my E-Mail mch2510@kingwoodcable.net
Old Oct 24, 2006 | 07:45 AM
  #62
MattsExcursion's Avatar
MattsExcursion
exposition- I will send that out
Old Oct 24, 2006 | 08:15 AM
  #63
exposition's Avatar
exposition
Keypad code.
Thank You . I appreciate your effort & expertise in solving this puzzle .
Exposition .
Old Oct 24, 2006 | 03:37 PM
  #64
scitzo_frenic's Avatar
scitzo_frenic
Easy code find
I have an 03 excursion and after reading the posts I went looking for the code for my door. I removed the 2 screws holding the trash bag hook plate in place and the module with the code was sitting there in plain view.
Old Oct 24, 2006 | 10:52 PM
  #65
MattsExcursion
I have a 2000 Excursion, and it is not there!
Old Oct 24, 2006 | 10:53 PM
  #66
MattsExcursion
exposition- no problem at all! glad to help!
Old Oct 24, 2006 | 11:37 PM
  #67
twobear's Avatar
twobear
Another humble request for the code macro. Thanks. ted_w_olds@yahoo.com
Old Oct 25, 2006 | 07:39 AM
  #68
MattsExcursion
twobear- I sent that out to you! good luck!
- matt
Old Oct 27, 2006 | 02:07 AM
  #69
housedad's Avatar
housedad
I have checked with my Ford Repair manual DVD's and have found that the module is called 2 different things depending on what year Excursion you have. I also found that the module is located in 2 different places. If anyone uses this, finds the keypad codes on the 200-2001 module, please do a photo write up of it and submit it as an article!!!
In the 2000-2001, it is called the Generic Electronic Module (GEM) —Generic Electronic/Central Timer (GEM/CTM) and is located behind the fuse panel. You have to dismantle the fuse panel to get to it.
2001 -02 instructions From the Ford DVD's:
The GEM controls a variety of systems:
  • 4-wheel drive functions
  • front and rear interval wiper/washer
  • warning chimes
  • keyless entry
  • interior and exterior lamps
  • power windows
  1. Remove the instrument panel steering column cover.
    1. Unlock the retainers.
  2. Remove the instrument panel steering column cover.
3. Disconnect the bulkhead connectors from the instrument panel fuse junction panel.
  1. Loosen the bolts.
4. Disconnect the bulkhead connectors.
5. Position the instrument panel fuse junction panel aside.
  1. Remove the nuts.
  1. Remove the bolts.
  1. Remove the generic electronic module/central timer module (GEM/CTM).
    1. Disconnect the electrical connectors.
    1. Remove the screws.
    1. Remove the GEM/CTM.
  1. To install, reverse the removal procedure.
In 2002 and up, it is located behind the radio in the center of the dash and it is called the Vehicle Security Module (VCM).
The VSM controls the following systems:
remote keyless entry (including panic feature)
computer-operated locks
autolamp
keypad keyless entry (Excursion only)
Old Oct 29, 2006 | 07:43 PM
  #70
hayklye's Avatar
hayklye
Smile Thank You for the help!
I have a 2003 Eddie Bauer EX and my door code was not in my paper work and the Ford dealershipship wanted the truck for sveral hours and an unknown price to get me my code. Everyone that has posted here helped me to find mine and the keypad now works! I took the trash bag holder out then the drink cup holder. I then looked to the left and was able to find the code! It was rather hard but like you guys said a good flashlight and alittle searching has me now being able to use the keypad. Thank everyone!
Old Oct 30, 2006 | 07:05 AM
  #71
rush2112's Avatar
rush2112
Matt,
Can you send me the codes at krumm_c@bellsouth.net? Thanks.
Old Oct 30, 2006 | 08:43 AM
  #72
MattsExcursion
Rush2112,
I sent you those codes... good luck!
-matt
Old Nov 1, 2006 | 11:12 AM
  #73
BIG BOI's Avatar
BIG BOI
matt if possible, could i also get a copy of that document sent to me, i'm tired of trying to find the code,
jomarjosh@hotmail.com
Old Nov 1, 2006 | 02:27 PM
  #74
MattsExcursion
Big boi,
I sent them out!
good luck!
-matt
Old Nov 1, 2006 | 03:22 PM
  #75
jrpoland's Avatar
jrpoland
I found my code written (by the previous owner) right there in the owner's manual....it might save you some work to check any paper documentation you have--maybe you'll get lucky like I did!
