mercon V ATF ?
Old Jul 31, 2006 | 08:54 PM
Blownpiston's Avatar
Blownpiston
Question mercon V ATF ?
Am going to refill my M50D R1 trans with fresh fluid. Can Mercon V be used instead of regular mercon trans fluid? I take it mecon V is sort of an synthetic based fluid?
Old Jul 31, 2006 | 09:18 PM
RangerPilot's Avatar
RangerPilot
Use whatever the owner's manual specifies, nothing else. If it calls for ATF, use ATF.
Old Jul 31, 2006 | 09:39 PM
Blownpiston
Rangerpilot, thanks. ill stick with the mercon/dexron 3. as book states.Just heard about all these guys swearing about synthetic this synthetic that.
Old Jul 31, 2006 | 09:42 PM
RangerPilot
If you want to go synthetic, go ahead, but make sure the fluid itself is the same type.
Honestly...there are some rumors that synthetics promote leaks, so I'd recommend staying with Mercon/Dexron 3. The good old stuff. You have done the mod to seal the shift rail plugs on the tranny, correct?
Old Jul 31, 2006 | 09:48 PM
Blownpiston
rangerpilot, Yes i have got the mods done. learned that right here on fte. i put all new clutch package in three mos. ago, got her back apart cause roll/spring pin somehow fell out of the 1st./2nd. gear shift fork. thank you, yo have saved me absolutely hundreds of dollars, as i lurk the board looking for info. Thanks.
Old Jul 31, 2006 | 09:55 PM
RangerPilot
We try. Lots of people come asking for info, I only wonder how many don't ever join, just poke around, find the info, and scoot along. I did it for about two days then realized this was home to me lol.
Old Aug 1, 2006 | 06:30 AM
Bob Ayers's Avatar
Bob Ayers
Mercon V is actually a synthetic blend. For the manual tranny either Mercon, or Mercon V should do ok, but for the automatics, stay exactly with whats recommended, DO NOT use multi-purpose ATFs!!!
Old Aug 1, 2006 | 08:37 PM
ColonyPark's Avatar
ColonyPark
If you want a synthetic ATF, you can get a Mercon/DextronIII in full synthetic. That's a much better way to do what you're trying to do.
Old Aug 2, 2006 | 01:22 AM
monsterbaby's Avatar
monsterbaby
RP, just to make things clear mercon V is ATF it's just a different blend than the older mercon blends, I believe Bob had it right. As I understand it, Mercon III is going to get hard to find in the near future for some reason, and I think your not going to hve a choice. Mercon V will work just fine but I would drain it as completely as possible not just use it to add to a trans that is leaking.
Old Aug 2, 2006 | 08:51 PM
Rockledge's Avatar
Rockledge
Yes, Ford now says that Mercon V is appropriate for all auto trannies that heretofore had required regular Mercon. IMO, Ford has (in all likelyhood) based this change of policy on the fact that most of the "older" automatic trannies that use to call for plain 'ol Mercon are either
(1) able to handle the "slippier" Mercon V in their original design without any issues,
(2) have been rebuilt with upgraded clutch components that can now better handle - maybe even utilize more fully - the different properties of Mercon V, or,
(3) are out of service by now in any case.
Old Aug 2, 2006 | 11:31 PM
Rockledge's Avatar
Rockledge
Forgot to cite the source of my info:
http://www.imakenews.com/lng/e_artic....cfm?x=b11,0,w
AmmoDawg
Jan 8, 2013 09:26 AM
Bananarama
Jun 27, 2011 03:27 PM
60RatRod
Dec 6, 2008 06:15 PM
chrison600
Apr 29, 2003 01:09 AM
jeff44ranger
Oil & Lubrication
Feb 5, 2003 01:49 PM
