I have found a bumper at pick and pull junk yard. What size nut is used on the bumper bolts? I don't want to have to drag my whole tool box to the back of the lot. Thanks.
Last week, I pulled the grill guard off my truck. It was held on via the bumper bolts in the stock location. I had to use an 11/16" socket on my '79. Good luck.
Just put the front bumper back on my 79. Takes a 11/16 socket. but for a pick and pull I would take a can of wd40, a 11/16 boxend and short handle hammer. It is going to be rusted on . good luck.
Thanks for the info everyone. I did get the bumper and it certainly helps the look of the truck. I ended up just shearing off the rusted bolt and picking up new bolts at AutoZone. Total time to remove and install was less than an hour.
