ubolts question
Old Jun 11, 2013 | 01:15 PM
ithaca1230's Avatar
ithaca1230
ubolts question
Gearing up to swap the bumpers and springs with Road Rhino front and rear bumper and v code and modded b code springs. I ordered the springs from Tousley Ford with new spring bolts and nuts and front u-bolts. My question is what size u bolts do we need for the rear modded b code springs and what bolt do we need to hold the spring together. If I have all the parts my mechanic will try and do them all in a day.
Thanks for all the help.
Old Jun 11, 2013 | 04:16 PM
housedad's Avatar
housedad
The Husky bolts from Rockauto work good and are cheaper than most. The 10.5 inch springs are for stock setup on f250/excursions
If you are doing the B mod AND taller blocks, get the13.5 inch . Measure carefully first.
Husky also makes a 12.5 inch version They come with the nuts
From rockauto:
<table class="main" style="margin: 0px; padding: 0px; border: 1px solid black; border-collapse: separate; background-color: white;" cellspacing="0"><tbody><tr><th>2005 FORD EXCURSION 6.8L V10 SOHC : Suspension : Leaf Spring Bolt <input title="View and Share Advice for These Parts and This Car" class="wiki_default" id="491wiki" type="button" value="Wiki"></th><th>Price</th><th id="node491altheading" style="padding-right: 5px; display: none; visibility: hidden;">Alternate</th></tr><tr style="color: red;"><td id="nopartsinmarket491" style="display: none;">No parts for vehicles in selected markets.</td></tr><tr class="part0" id="table491part0" name="pltr491"><td class="alternate0" rowspan="2"><table class="parts"><tbody><tr><td class="left" style="margin: 0px; padding: 0px;"><table class="layout" style="margin: 0px; padding: 0px;"><tbody><tr><td class="partlayout">HUSKY SPRING Part # UA203R <input title="Click for more information about this part" class="moreinfo_default" id="node491part0moreinfo" type="button" value="Info">
2WD; Exc. w/ Factory Contact Overload Springs; 5/8" X 3 5/8" X 10 1/2" Round Bend; w/ Deep Nuts & Thick Hardened Washers; For Rear Spring
4WD; Exc. w/ Helper Springs; 5/8" X 3 5/8" X 10 1/2" Round Bend; w/ Deep Nuts & Thick Hardened Washers; For Rear Spring
</td></tr></tbody></table></td><td class="right" style="height: 40px;">
</td></tr></tbody></table></td><td class="center leftrightborder boldfont priceonly alternate0" id="node491part0price" style="padding-top: 10px;">$10.19</td><td class="center boldfont leftrightborder pricebreakdown alternate0" id="node491part0altfiller" style="display: none; visibility: hidden;"></tr><tr class="part0" id="table491add0"><td class="alternate0 center" style="padding-top: 5px; padding-right: 5px; vertical-align: top; white-space: nowrap;"><input name="addtocart" class="addtocart_default" id="node491part0addtocart" type="button" value="Add Part"></td><td class="alternate0 center" style="padding-bottom: 10px; display: none; visibility: hidden;"><input name="alternate" id="node491part0alternate" type="checkbox"></td></tr><tr class="part1" id="table491part1" name="pltr491"><td class="alternate1" rowspan="2"><table class="parts"><tbody><tr><td class="left" style="margin: 0px; padding: 0px;"><table class="layout" style="margin: 0px; padding: 0px;"><tbody><tr><td class="partlayout">HUSKY SPRING Part # UA207R <input title="Click for more information about this part" class="moreinfo_default" id="node491part1moreinfo" type="button" value="Info">
2WD; w/ Helper Springs; 5/8" X 3 5/8" X 13 1/2" Round Bend; w/ Deep Nuts & Thick Hardened Washers; For Rear Spring
4WD; w/ Helper Springs; 5/8" X 3 5/8" X 13 1/2" Round Bend; w/ Deep Nuts & Thick Hardened Washers; For Rear Spring
</td></tr></tbody></table></td><td class="center leftrightborder boldfont priceonly alternate1" id="node491part1price" style="padding-top: 10px;">$10.93</td><td class="center boldfont leftrightborder pricebreakdown alternate1" id="node491part1altfiller" style="display: none; visibility: hidden;"></tr><tr class="part1" id="table491add1"><td class="alternate1 center" style="padding-top: 5px; padding-right: 5px; vertical-align: top; white-space: nowrap;"><input name="addtocart" class="addtocart_default" id="node491part1addtocart" type="button" value="Add Part"></td></tr></tbody></table>
Old Jun 11, 2013 | 05:18 PM
ithaca1230's Avatar
ithaca1230
Thanks for the reply. I'm gonna order a set from a local spring shop 13"X 3 5/8". bumpers coming off friday and springs going on monday.
Old Jun 11, 2013 | 05:37 PM
robert_l_ross's Avatar
robert_l_ross
Check local spring shops too...a local guy here bent mine for me on the spot for about $11/$14 a bolt.
Old Jun 11, 2013 | 06:55 PM
Kdr358's Avatar
Kdr358
I had my 4 U bolts made up by a spring shop, just under 50.00 for all of them with nuts and washers and it took them 2 minutes to make!
Old Jun 12, 2013 | 07:42 AM
ithaca1230's Avatar
ithaca1230
thanks Guys that's the route I'm going with. My mechanic ordered them from a shop.
Old Feb 2, 2014 | 02:49 PM
pennsylvaniabo's Avatar
pennsylvaniabo
So with a 3 springs added to a B pack, and a stock block, would I need a 13" u bolt?
Old Feb 3, 2014 | 02:02 PM
ithaca1230's Avatar
ithaca1230
It has been a while and I dont remember what we ordered. It was easy enough to add it up and add an inch or so then trim the excess off.
Old Feb 3, 2014 | 09:38 PM
ithaca1230's Avatar
ithaca1230
If you want I can measure them tomorrow.
Old Feb 4, 2014 | 05:51 AM
pennsylvaniabo
That would be awesome.
Old Feb 5, 2014 | 12:14 PM
ithaca1230's Avatar
ithaca1230
It has been snowing and haven't felt like crawling under the truck Will get to it as soon as it stops.
Old Feb 9, 2014 | 06:58 PM
pennsylvaniabo
Anyone else confirm any of these numbers?
Old Feb 13, 2014 | 02:16 PM
ithaca1230's Avatar
ithaca1230
Ok I finally crawled under the beast in the parking garage and meadured the U-bolts in the rear with modded B-code springs 13 1/2" I think we ordered 14 1/2 and then cut them. This is what they look like. Hope this helps.
Old Feb 13, 2014 | 03:08 PM
robert_l_ross
Not sure if anyone mentioned, but be sure to get the longer center bolt to account for the added leaves.
bsr99
Nov 29, 2018 08:22 AM
VaFordman26
Nov 9, 2017 06:30 AM
mrgrayaz
Jul 25, 2017 08:18 PM
Daewoo
Aug 22, 2016 10:09 PM
DeathRangerofDeath
Mar 5, 2016 04:58 PM
