For those of you with Bug deflectors??
on
Hey....
This the same thread you started back on 7/20/06!!
Well, here's my reply, again!
I have an OEM low profile bugshield. It has 2 stand-offs to keep it off the paint outside of the grill area.
Sure the shield is mounted between the grill and hood, but as long as it is tight, you should not have any problems.
I've had my truck up 90 mph and the shield does not move. If it did not have the 2 stand-offs, I could see that it would flap outside of the grill area and rub the paint.
Here's the link to your other thread...
https://www.ford-trucks.com/forums/s...d.php?t=510828
My AVS chrome shield on my 06 mounts in a way that no part of the shield itself touches the hood. Prolly a minimum of 1/2 clearance. It could marr the part of the grill trim it comes out of after mounting. Nuttin' to be done there, but wait yes their is! Put some clear mylar film on the mating surfaces first. Not the whole surface, but only at the "touch" points.
Happy F-150 ing!
Happy F-150 ing!
Originally Posted by wildcard30
Hey....
Originally Posted by Wedgewood Lariat
I have an '06 Screw and want to mount one. However, it mounts between the hood and grill. Can any of you check to see if it has wore away any paint where it mounts? I had a tundra that it happened to and don't want to go through that again. Thanks.
BTW I think that the only thing a "bug deflector" is good for is to keep rock chips off the front edge of the hood.
Originally Posted by bigdavewilson
The dealer where I got my 06 puts a deflector on virtually every truck they have on the lot. If they caused the problems you are referring to I don't think they would do that.
Remember the old style bug deflectors. Butt ugly straight up and down plastic. But guess what they worked!
