Where to mount gauges?
Old May 10, 2005 | 09:38 PM
whalerron's Avatar
whalerron
Where have you mounted gauges that you have added? I want to add a pyrometer and a transmission temperature gauge. I have seen the pillar mounts and I have seen gauges mounted in the dash to the left and right sides of the instrument panel. Are there any other options?
Old May 11, 2005 | 05:55 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
That is about all the options, or under the dash...the easy way is the "A" pillar, and very easy to read.
Old May 11, 2005 | 06:34 AM
BigF350's Avatar
BigF350
FTE Emeritus
On the hood is also an option...
Old May 11, 2005 | 07:05 AM
whalerron's Avatar
whalerron
Do you find that the A-pillar mounting blocks your vision to the left front corner of the truck? I have problems enough seeing around the grab handle and I don't want to completely loose vision toward that fender.
Also, recently, somebody posted a picture here with a gauge mounted on either side of the steering column. I was hoping to see that again.
Thanks.
Old May 11, 2005 | 07:11 AM
Maxium4x4's Avatar
Maxium4x4
I have pictures in my gallery of the pillar and steering mounted one. Lose the grab handle and you do not notice the A-Pillar at all.....and line of sight is important to keep an eye on gauges instead of looking down.
Old May 12, 2005 | 10:10 AM
bricot's Avatar
bricot
The steering column mount will partially block your view something on the '05's.
I went with a single gauge mount for the pyro since the '05 has an indicator, fits under the grab handle, looks really nice. Put a green LED in the gauge which comes close to the greenish glow of the instrument panel at night.
Krisverde
Feb 28, 2014 12:25 AM
jayro88
Jan 9, 2013 09:44 AM
my996duc1
6.7L Power Stroke Diesel
Dec 21, 2011 06:35 AM
MauleOne
Jul 23, 2010 10:27 AM
toddnga2002
Feb 1, 2003 11:15 AM
