Replacing Rod and Main Bearings-Pull engine?
Old Jul 27, 2006 | 09:56 PM
prblack's Avatar
prblack
Can I just lift the motor and pull the pan and replace them from underneath? Any other helpful hints?
Old Jul 27, 2006 | 09:57 PM
chrono4's Avatar
chrono4
Youl could do it from underneath, if it doesnt need any other work, machining wise.
Old Jul 27, 2006 | 10:01 PM
prblack's Avatar
prblack
Sorry I forgot to say it's a 1995 F150 4x4 5.8 liter, auto tranny.
Old Jul 28, 2006 | 08:12 AM
Conanski's Avatar
Conanski
That's an awful ugly way to do it!! You'll have to disconnect everything to get the motor high enough to get the pan completely off.. so you will only be a couple more pumps of the jack away from lifting the motor completely out. If you are replacing the bearings because of low oil pressure it'll need maching work as well.. so you are really talking a complete teardown.
Old Jul 28, 2006 | 09:10 AM
jas88's Avatar
jas88
I did that on my '91 Bronco (302) several years ago. It wasn't bad at all. Make sure you pull the fan off the motor before you lift it so that you won't break the fan shroud. I put pieces of 2x4 between the motor mounts and frame to hold the motor up. The hardest part was reaching up over the pan to pull the oil pump so I could get the pan off.
Old Jul 28, 2006 | 01:33 PM
Lazy K's Avatar
Lazy K
Akward but doable. Once the oil pan is off the big ends are easy. For the mains you will have to rotate the top shell halves out and rotate the new ones in. The down side is that it is not possible to clean the seats for the top shells really well. However it can be done and saves a lot of work.
Old Jul 28, 2006 | 09:58 PM
prblack's Avatar
prblack
If I jack the engine up just enough to get oil pan off, would I have to take the intake off and what about the tranny.
lil ford mec
Dec 21, 2013 07:25 PM
klmracing
Aug 8, 2011 05:19 PM
h2guy
May 7, 2009 10:54 PM
mh5500
Dec 12, 2008 05:55 AM
faceplant
1983 - 2012 Ranger & B-Series
Dec 26, 2005 03:22 PM
