replacing head gaskets.
Old Dec 21, 2013 | 06:35 PM
lil ford mec's Avatar
lil ford mec
Do I need to pull the injection pump when I pull the heads, I cant seem to get the darn intake gasket off???
Old Dec 21, 2013 | 06:52 PM
lindstromjd's Avatar
lindstromjd
Did you remember to take the big nut at the back of the valley off? It's been a long time since I had an engine torn down for head gaskets, but I do remember that I took my IP's off to do it. Don't know if it's necessary, but it worked for me to pull it out.
Old Dec 21, 2013 | 06:57 PM
lil ford mec
I did take that nut off and the four bolts on the front of the motor, if I pull the ip do I have to re time it? If so how do I do that?
Old Dec 21, 2013 | 07:03 PM
lindstromjd
It'll re-prime on it's own. If you have an electric pump that will make the process faster. If you want to, you can just leave the glow plugs out when you re-assemble everything and turn the engine over with them out for a few minute's worth of cranking. About 30 seconds of cranking to 1-2 minutes of cool down time. With the glow plugs out, the engine will crank over quite fast because it's not working against compression.
Your other option is to crack all the injector lines open and crank until you see fuel weeping from them. Once an injector is weeping fuel from the line, tighten it down. Some bleed out faster than others.
Old Dec 21, 2013 | 07:05 PM
lil ford mec
So I will not have to deal with timing:-)
Old Dec 21, 2013 | 07:07 PM
lil ford mec
Do I just undo the three bolts inbetween the ip and housing?
Old Dec 21, 2013 | 07:10 PM
lindstromjd
Just make a mark on the IP and the housing, so you know exactly where your timing used to be.
There's three nuts on the housing facing the firewall, and three bolts through the gear that you'll be able to get to by taking off the oil fill spout. That's about it. Just don't take the housing off. Creates a huge headache for figuring out the timing gear.
Old Dec 21, 2013 | 07:25 PM
Chevy_Eater's Avatar
Chevy_Eater
No, you do not have to pull the IP to pull the valley pan.
Fuzzydog
75
Oct 31, 2011 09:20 PM
charleswood6969
Mar 14, 2011 12:42 PM
DieselScoff
Dec 7, 2010 10:13 AM
lectricman
Nov 13, 2010 11:42 AM
dwkremer
Jun 14, 2009 11:20 PM
