Cleaning fuel injectors?
Old Jul 27, 2006 | 12:45 AM
DEAN BEAN's Avatar
DEAN BEAN
Question Cleaning fuel injectors?
I have a 300i inline 6. in my 1988 f150 custom. I changed plugs,wires,cap,fuel filter, the motor still has a rough idle. I am thinking of getting the fuel injectors cleaned. I was going to call some shops around my area for a quote .I dont no how the cleaning is done.do the injectors need removed to clean or can it be done with them in? whats the going rate for cleaning?
Old Jul 27, 2006 | 07:47 AM
SR_Crewchief's Avatar
SR_Crewchief
I'd start with running a bottle of fuel additive for injector cleaning first.
But if you think that the injectors are excessively fauled, then you could get an overhaul kit for them. The kit should include new screens and orings. You'll need to remove the upper half of the intake to get access to the injectors. The fuel rail will need to be de-pressurized before you start removing the injectors.
If you don't already have one, get a good maintenance manual. I believe that both Haynes and Chiltons will give you step by step instructions on how to do this.
Since this is the kind of thing I generally do myself I have no idea what a shop will charge, but the kit should run about $50. New injectors start around $250.
If you go this route it would be a good time to replace the valve cover gasket if it hasn't been recently. Odds are with an engine this old that gasket has developed a leak or two. Dealing with maintenance of the EGR and throttlebody would be advisable as well.
Old Jul 27, 2006 | 09:08 AM
quicklook2's Avatar
quicklook2
are you positive the plug wires are on correctly?
Old Jul 27, 2006 | 12:23 PM
andym's Avatar
andym
There's a guy on here who sent his fuel injectors out to get cleaned and rebuilt. Cruisin performance, i think, was the name of the place. I seem to remember it being about $12 per injector. You might want to check it out.
Old Jul 27, 2006 | 01:57 PM
fmr9's Avatar
fmr9
http://www.cruzinperformance.com/
Old Jul 28, 2006 | 11:06 AM
puck1263's Avatar
puck1263
Check for codes. Clean IAC and EGR. Change fuel filter. Run some TECHRON or SEAFOAM through the gas tank.
BocceMon
Apr 20, 2016 03:16 PM
evilwayz7
2004 - 2008 F150
15
Oct 20, 2015 04:55 AM
Renneberg
Aug 3, 2014 10:47 AM
jchosler
Feb 3, 2010 09:36 AM
hood
Modular V8 (4.6L, 5.4L)
Apr 4, 2006 08:10 AM
