Air Conditioning air direction
Old Jul 26, 2006 | 11:53 AM
big315's Avatar
big315
Monday, I got in my 2001 PSD Limited EX and I turned the air on MAX. It blew the air like it was on defrost. I slapped the dash and it started to blow out the vents. I have thought for a long time that something might be wrong because it feels like hot air blows on my feet when I have it set on Normal, so if anybody has any ideas, in the words or ROss Perot, "I'm all ears!"
John in Mobile
Old Jul 26, 2006 | 02:37 PM
Downriver Thunder's Avatar
Downriver Thunder
I had a similar experience a couple months ago but with my boss' Suburban. Was up north at the cottage and the drivers side pumped out cold air, while the passenger side blew out hot. It had automatic dual zone controls but after turning them on and off several times it corrected. Never happened again.
Old Jul 26, 2006 | 06:24 PM
Brians97F250Crew's Avatar
Brians97F250Crew
might be a vac leak in your system. Is it a diesel?
Old Jul 27, 2006 | 07:39 AM
big315's Avatar
big315
Yes it is a diesel! Can you tell me where to look for the problem.
Thanks,
John
Old Jul 27, 2006 | 09:15 AM
Brians97F250Crew
Mine had the same issues last weekend. I found that the vac line going to my heater hose shut off valve had come off. Might try that. If that's not it double check all the vac connections on the pump, cannister, ect..
Old Aug 9, 2006 | 08:32 PM
Xchick's Avatar
Xchick
Thanks for the suggestion! I thought I was going to melt this afternoon. Air would only blow out of the defrost vent. At least the window was nice and cool!
Old Aug 11, 2006 | 08:24 AM
XylemXorro's Avatar
XylemXorro
So where is the heater hose shut-off valve???
Old Aug 11, 2006 | 08:27 AM
Brians97F250Crew
should be in one of the heater hose lines going to the firewall. Look where the intercooler tube attatches to your turbo on the passenger side. Look directly behind the tube and you should see it. Just look for a little round can with a vaccume line going to it. Mine is black.
-Ross-
17
Oct 30, 2013 05:22 PM
Ross Matthews
Jul 5, 2013 12:34 PM
Manicford78
Jan 2, 2013 01:58 AM
rdunagan
Jun 10, 2011 09:35 AM
ross3170
New Member Introductions
Jan 7, 2008 12:08 PM
