Help ??
Old Dec 23, 2012 | 07:39 AM
Manicford78's Avatar
Manicford78
Question Help ??
I need the best way to go with pistons!!
Meaning I need help finding a piston that will bring compression
Up on my 460 ,stock truck rods,
D3 heads didn't want a dome or anything to radical
Jus wanna start with more compression with the d3's
Nothing like Ross,etc..way to expensive!!
D3's have 95cc chambers?
Thanks n advance
Manic78
Old Dec 23, 2012 | 10:43 AM
mark a.'s Avatar
mark a.
Around 95cc but always check. You will need to deck the block down a lot if you want to use a stock style piston. The '88-'93 FI pistons have a small dish and with the D3 heads you would be a little under 9.5:1. You are going to have to get it balanced too.
Old Dec 25, 2012 | 11:51 PM
Manicford78
Well the motor was bought from a local machine shop!!
I mean its brand new
I don't know how much was taken off the block nor the cylinder heads but prob jus tru'd up.
Truck rods have been reconditioned,New 40.over stock style pistons. Block
Heads,crank all rebuilt so I am at a lost with deck height etcit is a d9 block,d3 heads, I have the sheet with everything done to the motor but not measurements etc..
Thank but I am new to big block Ford's
I wanna spend my hard earned cash the correct way that's all..
I have been reading post an it only gets me more undecided on my combo..
Old Dec 26, 2012 | 12:07 AM
Manicford78
Thanks Mark
But here is my problems
The motor is brand new. Bought it from a local machine shop!
It's a d9 block,d3 heads. It has an overbore of 40.
Heads completely rebuilt,block has been line honed,surfaced along with the heads.
So I am guessing jus tru'd up. I don't know deck height measurement etc etc.
I have a sheet that states the actual work done a cost,but nothing including how much was taken off block nor heads. Crank has been ground, 10/10 truck rods reconditioned.
This is my first big block ford so I am so lost.
I have been reading so many post I have change my mind on which way to go so many times I stopped counting.
Jus wanna spend my pennies the correct way.
Looking for 375-400 hp
Thanks
Manic78
Old Dec 26, 2012 | 02:21 AM
monsterbaby's Avatar
monsterbaby
well figure out exactly what pistons you have and what the dish is. test fit pistons into the block and measure the piston to deck height. If .010 or more have it decked to bring it into that range (Make sure and do this with whatever piston you decide to go with)
Old Dec 26, 2012 | 05:08 PM
Manicford78
Hey sorry for the double post on the thread
Thanks Monster
Old Jan 1, 2013 | 09:47 PM
idt-572's Avatar
idt-572
A set of flat tops will put you under 10:1 with the D3's , but make sure it's zero decked and has a .041 gasket for good quench. Probably a good idea to add a small cam to kill just a tad of compression.
I have ran this combo a bunch with no problems on pump gas.
Old Jan 2, 2013 | 01:58 AM
mark a.'s Avatar
mark a.
So, are you saying it's all put together so you cant measure anything ? If so I'd go back to where you bought it and ask questions.
55 f250
Aug 1, 2023 12:30 AM
BigBlocker0248
Jan 17, 2016 03:20 PM
dutchlincoln79
17
Mar 16, 2008 03:47 PM
64fordf100292
Sep 1, 2007 06:59 PM
74crwcb429hibPS4spd
Apr 23, 2003 07:16 PM
