Help!! Can't Raise Engine
Old Jul 24, 2006 | 04:31 PM
bigblack302's Avatar
bigblack302
On my 89 f-150 4x4 5.0 5spd, I removed the bolts attaching the mounts to the motor. I placed a floor jack under the oil pan. When I attempted to raise the engine, the chassis moved with the motor. In other words, the motor never broke free from the mounts.
Anyone got any tips?
Old Jul 24, 2006 | 04:47 PM
RangerPilot's Avatar
RangerPilot
I'll ask the stupid question, did you disconnect the tranny, including the input shaft?
It may well just be worn into place over time, definetly do a once over, something is obviously holding firm.
RP
Zach
Old Jul 24, 2006 | 05:12 PM
Conanski's Avatar
Conanski
Check for ground straps.
Old Jul 24, 2006 | 05:13 PM
bigblack302
I didn't disconnect the trans. I don't see why you would have to pivot the motor up. Maybe I should have stated I'm doing this to change the oil pan gasket. I'm just looking to raise it a few inches
Old Jul 24, 2006 | 05:18 PM
MustangGT221's Avatar
MustangGT221
You shouldn't really lift the engine by the oil pan....the pan is not really strong enough nor is it made to do that. There is the oil pickup tube in that rear sump...which is made to be a specific height from the bottom of the oil pan and if you dent the oil pan it may screw that up.
You should be lifting it from the top.
The truck will lift up with the motor to some degree as you're removing that weight from the suspension (600+ lbs w/ some tranny weight).
You should loosen the tranny mount.
Look around the engine and look for a possible source of an issue...check the exhaust too...
Question...why did you remove the bolts from the mount to the engine....instead of from the engine mount to the frame mount...?
There are two bolts that hold the rubber mount to the engine...and one bolt from that rubber mount to the frame bracket. It would be easier to get the engine back into position if you leave the rubber mount on the engine and just remove that 1 bolt holding the rubber mount to the frame mount.
Old Jul 24, 2006 | 05:54 PM
bigblack302
good point. I didn't think about that.
I'll try that. Thanks for you help....
Old Jul 25, 2006 | 08:21 AM
trgrhappy's Avatar
trgrhappy
Just an observation here, but when I pulled my engine last weekend, the truck lifted the first 6" with the engine before seperating. It didn't drop back down untill I re-installed the engine. Fairly normal compared to all the other engines I've pulled/raised in my life.
Old Jul 26, 2006 | 08:59 AM
MustangGT221
6"?? That sounds like a real lot of room.
I've pulled 4 engines and put in 3 over the last year and didn't notice any height change more than like 2".
Old Jul 26, 2006 | 12:10 PM
andym's Avatar
andym
I'll let you in on a little secret - you don't have to raise the engine to change the gasket. If you unbolt the pan it will drop down far enough to get the old gasket out and get the new one in, even with a felpro one piece gasket. I've done it on both 2wd and 4wd trucks.
Old Nov 10, 2019 | 01:53 PM
Thunderkiss1965's Avatar
Thunderkiss1965
How do you get the mating surfaces clean enough to deal with the pan in there? Or inspect the big end bearings, oil pick up and the like?
pswann64
Modular V8 (4.6L, 5.4L)
Jul 29, 2024 01:38 PM
Jnissen04
Aug 15, 2014 07:11 PM
darkstar8
Sep 11, 2011 07:35 PM
mantta
Sep 14, 2007 10:49 PM
mechanicblue3
Jun 10, 2006 06:24 AM
