1993 Ranger not charging
Old 07-22-2006, 05:25 PM
Rudude8960's Avatar
Rudude8960
Rudude8960 is offline
I need some help, my Ranger is not charging. I changed the Alternator and the Battery and still not charging. Any ideas? Thanks in advance for your help.
Old 07-22-2006, 09:00 PM
92SXT's Avatar
92SXT
92SXT is offline
check your cables, look for loose connections, broken wires, disconnected connections or connections that are half on and not connected
Chances are you lost a ground somewhere, is my guess...
Old 07-22-2006, 10:02 PM
RangerPilot's Avatar
RangerPilot
RangerPilot is offline
Check the engine block-frame ground cable.
RP
Zach
Old 07-22-2006, 11:22 PM
Rudude8960's Avatar
Rudude8960
I will check that tomorrow and let you know if that was it. Thanks for the advice.
Old 07-23-2006, 12:41 AM
RangerPilot
Keep us updated.
RP
Zach
Old 07-23-2006, 03:42 AM
FTE Trigger's Avatar
FTE Trigger
FTE Trigger is offline
I think you have a Fusible link somewhere in between the Battery and the Alt. too?
You should be able to find it (if its there) when you start checking your cables.
Old 07-23-2006, 07:52 AM
pawpaw's Avatar
pawpaw
pawpaw is offline
Why not consider running this puppy by your favorite atoparts store, for a no cost, in vehicle, electrical system check up, via their portable electical system tester. It'll likely sniff out the culprit!!!!
Let us know what you find.
Old 07-23-2006, 10:35 AM
Rudude8960's Avatar
Rudude8960
Guys,
Thanks for all the info. This is really helpful and gives me many options to check. You guys are awesome. I will keep you posted. Thanks again!!
Old 07-23-2006, 11:10 AM
Rudude8960's Avatar
Rudude8960
Thumbs up
Guys,
You guys are the best!!! Checked everything you suggested and found the problem. There is a fuse in the fuse box labeled wrong. That was the bad one. Go figure!! Anyway, you all saved me lots of money and I really thank you for your help. Hope I can help guys if you have any problems with your autos.
Thanks again,
Rudy
Old 07-23-2006, 12:17 PM
RangerPilot
Glad ya got it fixed!
RP
Zach
Old 02-01-2009, 01:19 PM
Rudude8960's Avatar
Rudude8960
1993 Ranger blinkers not working
Any idea on how to change the blinker switch in the steering wheel column? Flashers work ok. Thanks for the help.
dddenio
50
08-01-2019 12:34 PM
1977fordf100ranger
07-29-2012 10:03 PM
98Ranger2.5
1999 to 2016 Super Duty
08-08-2010 10:29 AM
BlueOvalLover
05-22-2008 12:29 PM
dgalloway
01-05-2005 08:27 PM
Quick Reply: 1993 Ranger not charging
