1993 Ranger not charging
Old Jul 22, 2006 | 05:25 PM
Rudude8960's Avatar
Rudude8960
I need some help, my Ranger is not charging. I changed the Alternator and the Battery and still not charging. Any ideas? Thanks in advance for your help.
Old Jul 22, 2006 | 09:00 PM
92SXT's Avatar
92SXT
check your cables, look for loose connections, broken wires, disconnected connections or connections that are half on and not connected
Chances are you lost a ground somewhere, is my guess...
Old Jul 22, 2006 | 10:02 PM
RangerPilot's Avatar
RangerPilot
Check the engine block-frame ground cable.
RP
Zach
Old Jul 22, 2006 | 11:22 PM
Rudude8960's Avatar
Rudude8960
I will check that tomorrow and let you know if that was it. Thanks for the advice.
Old Jul 23, 2006 | 12:41 AM
RangerPilot
Keep us updated.
RP
Zach
Old Jul 23, 2006 | 03:42 AM
FTE Trigger's Avatar
FTE Trigger
I think you have a Fusible link somewhere in between the Battery and the Alt. too?
You should be able to find it (if its there) when you start checking your cables.
Old Jul 23, 2006 | 07:52 AM
pawpaw's Avatar
pawpaw
Why not consider running this puppy by your favorite atoparts store, for a no cost, in vehicle, electrical system check up, via their portable electical system tester. It'll likely sniff out the culprit!!!!
Let us know what you find.
Old Jul 23, 2006 | 10:35 AM
Rudude8960's Avatar
Rudude8960
Guys,
Thanks for all the info. This is really helpful and gives me many options to check. You guys are awesome. I will keep you posted. Thanks again!!
Old Jul 23, 2006 | 11:10 AM
Rudude8960's Avatar
Rudude8960
Thumbs up
Guys,
You guys are the best!!! Checked everything you suggested and found the problem. There is a fuse in the fuse box labeled wrong. That was the bad one. Go figure!! Anyway, you all saved me lots of money and I really thank you for your help. Hope I can help guys if you have any problems with your autos.
Thanks again,
Rudy
Old Jul 23, 2006 | 12:17 PM
RangerPilot
Glad ya got it fixed!
RP
Zach
Old Feb 1, 2009 | 01:19 PM
Rudude8960's Avatar
Rudude8960
1993 Ranger blinkers not working
Any idea on how to change the blinker switch in the steering wheel column? Flashers work ok. Thanks for the help.
dddenio
50
Aug 1, 2019 12:34 PM
1977fordf100ranger
Jul 29, 2012 10:03 PM
98Ranger2.5
Aug 8, 2010 10:29 AM
BlueOvalLover
May 22, 2008 12:29 PM
dgalloway
Jan 5, 2005 08:27 PM
