I would go with the one from idle to 6800. the other one is only rated to 7000 rpm,only 200 more and doesn't come in until 1500. I am running the idle to 6800 on my 78 f100 with a 351w and love it. You have to decide how much time the motor will be spending at the upper rpm ranges before you sacrifice low rpm power. Maybe go for the higher rpm one if you are planning on going to the drag strip with the car.
id go with edelbrocks new performer rpm air gap intake, running one on my 351w and they seem to work great. on summit racings site the part number is edl- 7521
All these intakes work from idle to whatever rpm you want: (despite what they advertise) Performer RPM (air gap too) Edelbrocks older F4B, Ford's C9OX, A321(current version of the C9OX & F4B) Shelby Cobra highrise dual plane(also the same intake as the previous three) & Weiand's Stealth. Don't buy into the "works from 1500 to whatever" B.S., highrise dual plane carb intakes are not rpm sensitive. I've run too many to know better. They ALL work from idle to what your motor will pull.They will also work well on stock to wild engines. If you want stock performance get the Performer or a factory 4 bbl intake (either the 60's iron version or the mid 80's aluminum 4 bbl Mustang intake) These will also pull from off idle but the power will shut off at around 4500-5000 rpms.
agree with baddad 457 only other thing id say thats nice with the performer rpm air gap is it seperates the ports from the bottome of the intake to make the air going into the motor cooler. in theory anyways hehe.
The stealth is a better all around manifold. If your making a track burner you might want to go to the single plane. Both of those manifolds are pretty tall compared to stock. Make sure you have room under the hood for the one you choose.
i may be wrong but on something light like a mustang and on a 289 that is pretty commonly a high reving engine i dont see why the big concern with off idle. i understand that on heavy trucks though
It's not really a concern, it's just that most people who have had no experience in this take it for granted that seeing as the catalogs give an rpm range of say 1500-6500 rpms for a certain intake, think that they don't work or are not good performers at any rpm under that. Single plane carbed intakes are a whole 'nother story. You can get them to work at lower rpms, and some do anyway, but they take more effort to do so.
