Suspension ?
Old Aug 30, 2008 | 06:54 PM
SuperSnake's Avatar
SuperSnake
Suspension ?
<!-- / icon and title --> <!-- message --> I know parts will interchange between 80-86. But I am wondering if thes drom beams from Bell Tech will work on my truck they are for a 87-93 F150?
http://store.summitracing.com/partdetail.asp?autofilter=1&part=BEL-4010&N=700+400013+4294908331+4294908312+4294924761 +115&autoview=sku
Rear
http://store.summitracing.com/partdetail.asp?autofilter=1&part=BEL-6415&N=700+400013+4294908331+4294908312+4294924761 +115&autoview=sku
Old Sep 4, 2008 | 11:45 AM
mudgepondexpress's Avatar
mudgepondexpress
I used the last years of our body style on my 1981 and it bolts up fine. I believe it is 92-96 and they were from DJM (through Summit). Here is what I learned....
Rotors/bearings...no change
Radius arm bushings...no change
Radius arm brackets...no change
Radius arms...change
Sway bar bracket...change
Drag Link/Tie Rod/Rod ends...change
Spindle...change
Brake caliper...change
Brake hose...no change
Springs...no change
Spring pad and radius arm bolt...change
Granted...i had an 81 that was a kingpin version. The steering components had to be 92-96 only to bolt to the 93 spindles. If you have a manufactured beam you probably need a lot less parts...if a cast beam, you will need more.
As for the rear, the later drop setup (87-96) worked fine on my 81.
Hope it helps some....
Kenny
Old Sep 4, 2008 | 07:27 PM
SuperSnake's Avatar
SuperSnake
Thanks Kenny it does.
Moore558
Apr 30, 2017 12:58 PM
jimbo beam
Apr 18, 2009 04:47 AM
Tylus
2004 - 2008 F150
20
Feb 14, 2009 11:33 AM
peckhamjusten
Computer Chips & Tuners
Nov 12, 2008 01:00 AM
khadma
Oil & Lubrication
Feb 24, 2008 09:27 PM
