Sponsored by: Kumho
coil spring compressor
Old Jul 21, 2006 | 08:31 PM
truckman01's Avatar
truckman01
Can I install front coils on my 94 f150 without the use of a compressor? I thought for sure I would need one but my repair manual doesn't mention using one.
Old Jul 21, 2006 | 08:50 PM
AFSOCmech's Avatar
AFSOCmech
To be on the safe side, and avoid a trip to the dentist, use one. I haven't taken them off my trucks, but I've done them on other vehicles and they can be unpredictable.
Old Jul 22, 2006 | 06:30 AM
Lou Braun's Avatar
Lou Braun
The last time I did a coil spring replacement on an F-150, no spring compressor was needed.
Just jack up the front end and put the frame on jackstands to unload the front suspension. The coil springs go to full extension and can be removed and replaced without using a compressor.
The hardest part of the job is removing all of those tight and rusty bolts.
Lou Braun
Old Jul 23, 2006 | 08:04 PM
truckman01's Avatar
truckman01
Thanks guys.
Old Jul 23, 2006 | 11:37 PM
omni's Avatar
omni
are you putting in longer coils than the stock ones, if so i would get a spring compressor, what do you have to support the truck under the frame? it sounds easy but you have to get a lot of height to get that truck up there, so the front end will hang. I know, I just did this. be careful
bruno2
123
Mar 9, 2016 09:02 PM
greatbatchw
Jul 21, 2015 02:40 AM
joegeds
Feb 21, 2014 02:04 PM
bruno2
Apr 3, 2012 06:20 PM
aerocolorado
Aerostar
13
Nov 13, 2006 03:26 PM
