A/C Compressor
Old Jul 20, 2015 | 12:01 PM
greatbatchw's Avatar
greatbatchw
A/C Compressor
I have searched over and over, but I can't seem to find if anyone knows if the electrical connector on compressor clutch field coil has power to both wires, or just one of the two wires. If the latter, which one? Thanks
Old Jul 20, 2015 | 12:58 PM
dannyboy950's Avatar
dannyboy950
I really do not remember which is power. But the 6.0 the a/c clutch is on it's own fuse.
Underhood box Fuse #17 10 Amp. The controls are on a seperate circuit.
Underdash box # 23 20 amp.
Old Jul 20, 2015 | 03:11 PM
greatbatchw
Thanks, I already knew that the clutch was on its own fuse (#10 - 10amp under the dash) and relay (under the hood). I was wondering because I wanted to check to see if I was even getting power to the clutch since it wasn't engaging like it should, either because the R134A was too low or the solenoid was shot on the clutch. I ended up pulling the relay, then jumped it to see which one was "hot", which was the top one by the latch on the connection, plugged the connector back onto the compressor and realized that the solenoid was malfunctioning which means a whole new compressor. Thanks again for the words of wisdom.
Old Jul 20, 2015 | 10:31 PM
78fordman's Avatar
78fordman
A/C Compressor
You can change the clutch and coil out for about a 100 bucks, I did mine with a bearing in chassis.
Old Jul 21, 2015 | 02:40 AM
Yahiko's Avatar
Yahiko
Some photos.
In the order that they come off here in the first photo.
Hope this helps you some.
Sean
6.0L Tech Folder
fwjumper
Oct 11, 2013 06:57 PM
Diesel_Brad
13
Jun 26, 2012 03:31 PM
Monsta
Apr 21, 2012 07:05 PM
2000Ford2000
13
Aug 17, 2007 09:58 PM
SD2503/4ton
Dec 5, 2004 03:28 AM
