New DP-Tuner & Valve Body Installed
Old 07-18-2006, 09:36 PM
RAMPAGE_F350's Avatar
RAMPAGE_F350
RAMPAGE_F350 is offline
Talking New DP-Tuner & Valve Body Installed
First of all, I would like to thank everyone who posted and recommended the DP-Tuner and the valve body upgrade. Secondly, I want to point out that I was on the fence for months about making the leap from my Predator and Sonnax. Thirdly, WHY DID I WAIT SO LONG?
Normally, I'm very easy on the go pedal, hell I've never had it at WOT. So when I test drove my mule on the 80 econo I noticed quite a bit more power and she shifted like a dream. I felt pretty comfortable so I shifted it into 120... I was doing about 10 mph and I gave it about half throttle...my truck(all four wheels) broke looseand we were off! The smoke let me tell you about the smoke, black and thick!! Using my Predator I only got a light grey smoke while towing 9K up steep grades. So, this is very new to me. I only went about 5 miles on my test drive and let me tell you that it was worth every penny.
The display is nice and the **** to switch is on the display, now I have to find an ideal mounting location.
Old 07-18-2006, 09:43 PM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
PowerstrokeJunkie is offline
oh cool, i think you are one of the first with a display chip here. lovin' it, huh?
what programs did you get? i priced out my dream 10pos. chip the other day.. .wow.
Old 07-18-2006, 09:49 PM
jtharvey's Avatar
jtharvey
jtharvey is offline
Got any pics of the new chip?
Old 07-18-2006, 09:51 PM
RAMPAGE_F350
0-no start (unhooking the display)
1-stock
2-40 tow
3-60 tow
4-80 tow
5-80 econo
6-120 race
Old 07-18-2006, 10:14 PM
lethal5point7's Avatar
lethal5point7
lethal5point7 is offline
I must say the same about my experience since just installing my DP-Tuner, valve body and converter (BTS). It's like an entirely new truck, hard to explain (but I don't have to because most people already know!)
Old 07-19-2006, 09:16 AM
Chance_Thomas's Avatar
Chance_Thomas
Chance_Thomas is offline
Please post your pics. I'm still waiting for my toy to arrive.
Old 07-19-2006, 09:26 AM
RAMPAGE_F350
I'll take some pics tonight after work. But, Jody has pics of the same unit on his web site.
http://www.dp-tuner.com/7.3%20pricing.htm
Old 07-19-2006, 01:26 PM
schlichtemeier's Avatar
schlichtemeier
schlichtemeier is offline
I ordered the DP-tuner and it is supposed to be shipped tomorrow. I ordered the same setup w/o the 120 hot rod setting.
Old 07-19-2006, 02:20 PM
Chance_Thomas
I ordered mine last week and Jody still doesn't have any in stock. It was supposed to be delivered this week but probably next week.
Old 07-19-2006, 05:59 PM
RAMPAGE_F350
Talking
Here is the display unit, note the circle on top, that is the digital display. The **** on the bottom is the selector switch. The switch has 16 positions, so if you order a 6 position tuner for example, the **** will switch beyond #6 but will default to the highest setting. The display unit is a little bigger than the FOB for your truck.
Old 07-19-2006, 06:05 PM
RAMPAGE_F350
Another picture. There is a nine pin connector on the back that is very easy to disconnect, but not easy enough to vibrate loose. I use these same type of connectors on some telecommunication equipment at work. They work very well, I also recommend using velcro with 3M adhesive backing to attach it to your mounting location.
Old 07-19-2006, 06:10 PM
RAMPAGE_F350
Yes, I did drill and trimmed a rectangular hole for the connector to come through the dash. If you want more pictures of the ribbon cable and the chip itself go here:
Old 07-19-2006, 06:17 PM
jtharvey's Avatar
jtharvey
jtharvey is offline
Looks pretty good! Does the **** make a definite turn for each position, or do you just turn it one way and it returns to a neutral position?
BTW I talked to Jody a few minutes ago and the chips were delayed coming in. He thought they were going to have them last week, but they obviously didn't make it. Tomorrow, 10 chips are supposed to arrive to Jody.
Old 07-19-2006, 06:22 PM
arninetyes's Avatar
arninetyes
arninetyes is offline
The only problem with the BTS valve body and the 120hp position on Jody's chip - while shifting is much improved, a BTS tranny it isn't. The 120hp position makes so much power I fear for the safety of my trans.
As a result, I seldom use it. Maybe someday, IF I have to replace my tranny with a better one, OR I replace it with a real transmission (6 gears + clutch = no slushing).
Old 07-19-2006, 06:27 PM
jtharvey's Avatar
jtharvey
jtharvey is offline
In my experience, an automatic + full BTS build also = no slushing.
