Garage & Workshop Tips & Ideas for the garage or workshop. No Truck Tech Discussion
'unbreakable' socket universal joint
Old Jul 19, 2006 | 09:07 PM
sierraben's Avatar
sierraben
Here's the uni I use.
It's a 1/2" drive, 1 3/16" dia., and is 2 1/2" long.
The other contraption is my 1/2" drive 1/2" keyless chuck for impact guns.
Old Jul 19, 2006 | 11:07 PM
bigrigfixer's Avatar
bigrigfixer
The Pacifier
I got the same thing as Rebocardo except mine are Westward. Got them in 3/8 and 1/2, both have the safety ring on them.
And I'd use either of them with a torque wrench before I even consider using a u-joint again. I've exploded a few.
Old Jul 20, 2006 | 06:29 AM
lo's Avatar
lo
The wobble extension is a good idea. I need about 15 or 20 degree angle, which may be too much for wobbles.
Where can I find good impact swivels? The pictures don't show it but I'm guessing there is a 1/2" or 3/8" square hole in the other end...corrrect?
Old Jul 20, 2006 | 11:19 AM
rebocardo's Avatar
rebocardo
Well, since I have a Snap-On, I would have to say Snap-On. Though item#
Stock#: IP83 at $138 might be a bit rich for one time use.
Correct.
Try this at Northern Tools:
http://www.northerntool.com
Item# 14678
Northern Industrial Tools Impact Socket Set — 7 Piece, 3/8in. Drive, SAE
Now you can reach those awkward spots with your impact wrench to get the job done faster! Extra heavy duty impact sockets swivel on universal joints. Rugged, heavy duty treated black chrome vanadium steel with tough industrial finish. Standard 6-point design. With steel case. 7 sizes: 5/16, 3/8, 7/16, 1/2, 9/16, 5/8, and 11/16in.
$22.99 might be a more viable option for one time use and since you are not using an impact for final tightening, you do not have to worry about them exploding in your face.
<!-- specifications tab content -->
Old Jul 20, 2006 | 11:26 AM
fellro86's Avatar
fellro86
Might be bought for one time, but my experience is that once you have it, it gets used.
Old Jul 20, 2006 | 12:05 PM
1975Ford's Avatar
1975Ford
Maybe if it a one time use, borrow one from a mechanic or buddy, or have a buddy borrow one for you.
Old Jul 20, 2006 | 02:26 PM
RockyMtnF250's Avatar
RockyMtnF250
Have you ever seen someone spin one of those impact swivels up without the socket on the nut using an impact, I was present when a guy did just that. The socket held on just short of the time it takes to achieve escape velocity, nice flat trajectory after letting loose, it seemed to have a seek function, struck a windshield and destroyed it! As far as unbreakable there wasn't a scratch on the projectile!
Old Jul 21, 2006 | 10:44 PM
bigrigfixer
The Pacifier
I lose sockets off the end of my impact swivel adapter every once in a while. If the socket isn't on the fastener fully and completely, it'll fly. Once you sense it's coming off, shut your eyes, shut your mouth, and turn your head. It'll take an eye or tooth out easily. Like rockymtn said, it flies straight until it hits something.
Old Jul 22, 2006 | 01:53 PM
CheapRanger's Avatar
CheapRanger
As for sockets coming off of impact universals, THIS IS why you should buy PIN style. Barring the socket splitting and breaking, it doesn't come off, unless you manually pull it off while pressing in the pin.
65fstback
Jan 21, 2008 07:20 AM
syannuzzi
Aug 28, 2007 08:43 AM
Lanny Sutton
Mar 30, 2007 07:23 PM
bigredbronc2002
1978 - 1996 Big Bronco
Jan 27, 2004 04:26 PM
EPNCSU2006
Dec 10, 2002 06:24 PM
