Garage & Workshop Tips & Ideas for the garage or workshop. No Truck Tech Discussion
'unbreakable' socket universal joint
Old Jul 17, 2006 | 11:51 AM
lo's Avatar
lo
I need to torque a hitch bolt to 95 ft-lbs. I need a universal joint to get at it. I twisted a previous universal, but that may be because it was 3/8 drive or that it was an Autozone brand. Would a 3/8 Craftsman universal hold up? I'm not sure I can fit a 1/2 drive universal in this tight spot. Any suggestions?
Old Jul 17, 2006 | 12:21 PM
Mr.One's Avatar
Mr.One
You used Duralast brand?,Buy the Craftsman set of universal joints
Old Jul 17, 2006 | 02:01 PM
1975Ford's Avatar
1975Ford
Buy the impact style universal joint, they hold up much better, the only draw back is the angle of u-joint is minimized.
Old Jul 17, 2006 | 11:40 PM
rander101's Avatar
rander101
For 95 ft-lbs you probably should be using 1/2" drive sockets, especially if you are using a swivel socket.
Old Jul 18, 2006 | 09:02 AM
Fordzlla's Avatar
Fordzlla
I was taught never to use a universal joint with a torque wrench.
It's nearly impossible to get an accurate reading because the angle of the universal alters the effective distance from the handle to the fastener.
Old Jul 18, 2006 | 09:17 AM
1975Ford's Avatar
1975Ford
As long as the universal joint is not angled to much when torqued.
Old Jul 18, 2006 | 09:35 AM
lo's Avatar
lo
There is no way to get to this bolt except thru a universal. It won't be angled very much. I agree that the angle thru the universal will alter the effective torque arm and therefore the reading won't be accurate. The torque spec has a decent +/- tolerance so if I aim for the middle, it should be OK.
How about the Lowes Kobalt brand......any good?
Old Jul 18, 2006 | 09:52 AM
1975Ford's Avatar
1975Ford
Not a bad brand, it made in the U.S.A., good metal content.
Old Jul 18, 2006 | 07:30 PM
sierraben's Avatar
sierraben
lo, if it's not much of an angle, get a impact universal, like 1975Ford mentioned.
There a bit tougher.
Old Jul 18, 2006 | 07:50 PM
fellro86's Avatar
fellro86
Maybe look for an extension that allows some wobble, they are designed that way so you can use them in situations like yours.
Old Jul 18, 2006 | 08:11 PM
sierraben's Avatar
sierraben
I think it's called a wobble extension.
Old Jul 18, 2006 | 10:52 PM
fellro86's Avatar
fellro86
that's what I was thinking, just didn't get it down...
Old Jul 18, 2006 | 11:02 PM
sierraben's Avatar
sierraben
I already knew what you were talking about.
Old Jul 19, 2006 | 04:05 PM
rebocardo's Avatar
rebocardo
I use impact swivels and impact wobbles. As someone noted, the swivel UJ type things do poorly with a torque wrench.
Here is my impact swivel, Snap-On, 3/8. It measures exactly 1" in diameter. It will hold to 95 foot pounds using a 1/2" bolt.
Old Jul 19, 2006 | 04:10 PM
1975Ford's Avatar
1975Ford
Now that is an impact socket, I have and use the same one.
