Tranny Temp Question
Old Jul 13, 2006 | 04:03 PM
Tazzmann's Avatar
Tazzmann
No it dident leak, It just got clogged up or jammed or something. It wouldent allow a good flow of tranny fluid through, so in a 20 min freeway drive the temps would get to 220+
Old Jul 18, 2006 | 01:48 AM
Tazzmann's Avatar
Tazzmann
Still trying to figure this out, over the weekend I pulled a 2000 lb trailer and after an hour in 100 deg heat the tranny temp was 220 deg. This is so frustrating!
Old Jul 18, 2006 | 06:01 AM
stuart1's Avatar
stuart1
Is the fan working properly?
Do you have any obstruction in front of the grill?
Is the radiator and a/c condensor free of debris?
Old Jul 18, 2006 | 06:37 AM
Cuda_jim's Avatar
Cuda_jim
Is you tran still slipping?
Old Jul 18, 2006 | 10:13 AM
DAVID'S97F250HD's Avatar
DAVID'S97F250HD
WHATS YOUR rpm, if the torque converter is not locking up then you'll have fluid sheer in the tourque making it heat up.
As for me, my transmission temp I read off the side plug of the tranny, I'm pulling 178-180 sometimes hitting 190 on 98 degree days city driving, 180 highway driving, 180-185 pulling at cruising speed loaded 14,000lbs all on the prairies.
You say you had a blockage, pull your lines at the the tranny, reverse flush the lines, you'll figure out which line is to your coolers by driving the truck, get the tranny hot, shut her down for 15 minutes till the lines cool down, then get someone else to start the truck with your hands on both lines, the first line to get hot is your exit line, so on the other line blow out your coolers.
If you had crap get into your liquied to liquid cooler, very good chance you have crap in your lines, sounds like your having a flow issue in your lines.
Old Jul 19, 2006 | 04:15 AM
Tazzmann's Avatar
Tazzmann
Thanks for the responses guys, I did check to make sure there were no obstructions. Both of the coolers are right behind the grill so there is a good spot. I'll have to try to blow the lines out again and see if there is an obstruction, the coolers get real hot to the touch so I know there is some flow.
David my temp numbers seem to match your up until I pull a load of any kind then it just seems to steadly climb up into the 210+ range, I'm generally running in the 2500 rpm range on the freeway commuting to and from work, how will I know if the torque converter isent locking up properly?
Old Jul 19, 2006 | 07:12 AM
DAVID'S97F250HD
what gear ratios do you have, I have 3.54 or 3.55's, jeez I cant remember now, I need my morning coffee, any ways, at 70mph I'm running at 2000rpm give or take.
Baically watch your RPM on the highway, when your cruising lets say 70mph and you give it some throttle your rpm should nicly increase at the same rate as your speed when locked up, if your cruising and you step on the throttle and the rpm jumps up when you step on the throttle or decrease quite a bit when release your tourque converter may not be locking up.
for my tranny, I start in 1st gear, 2nd gear, 2nd gear torque lock up, 3rd gear instant lock up and 4th gear instant lock up like driving a standard. Thats empty of corse, have not had the chance to pull a trailer to see what happens since I changes all my springs and my selinoid pack to the stage 2.
Old Jul 19, 2006 | 08:52 AM
zephcom's Avatar
zephcom
The easiest way to tell if your torque converter isn’t working properly is to take it to a reputable transmission shop and have them check it out for you. Usually a quick test drive is all it takes.
Another thought comes to my mind. You don’t mention your driving habits when towing. My experience with a tranny temperature gauge while towing is that the torque converter unlocks very quickly if too much power is delivered by the engine. I learned that I could never do more than just barely crack open the throttle or the temperature would start rising immediately.
Keeping the fluid temperature down became a dance between careful throttle work and manually downshifting anytime I needed more than just a moderate amount of power. It became so frustrating that when I went looking for my last truck the only specification that was non-negotiable was a manual transmission. It is crazy to have that much power under the hood and not be able to use it without toasting the transmission.
Old Jul 19, 2006 | 10:51 AM
DAVID'S97F250HD
Thats why I'm looking foward to pinning up a heavy load cause of this, spent $440 on springs and selinoids on my tranny, empty right now other then 1st gear feels like I'm driving a standard transmission. I really want a good torque converter now, I'm feeling it in first gear how much the torque converter sucks
Old Jul 26, 2006 | 05:05 PM
Tazzmann's Avatar
Tazzmann
Ok after further studying and callng around it seems that the torque converter is the culprit with the tranny acting wierd. Ive allways just assumed it was tranny slippage but it looks like more the TC. Whats a usual price on these, or what kind of options do I have? I dont mind putting the work in and changing it myself.
Old Jul 27, 2006 | 12:19 AM
DAVID'S97F250HD
Dont know where you are but, depends what your looking for, where I am at I can bring my old Torque converter in and they test/cut/open/rebuild them and I can have the option of them throwing in a triple plate lock up for like $700 or something. Or just find a good used one or go all out, ask around maybe, I'm still runnning my stocker
billbot
Jan 13, 2014 09:29 AM
fullsize4wd
Aug 17, 2013 06:10 PM
mrad
Aug 19, 2010 04:16 PM
mjsparky363
Apr 29, 2007 07:55 PM
Pigeon
Aug 27, 2006 05:57 PM
