how much paint?
Old Jul 10, 2006 | 12:06 PM
dbuck50's Avatar
dbuck50
how much paint?
I am going to try to paint my 93 F150 longbed and want to know how much paint will be needed for single stage? Would 1 gallon be enough?
Also, I'm not removing the old paint, just sanding a little. Do i need a sealing primer or a self-etching primer?...what's the difference?
Old Jul 10, 2006 | 03:54 PM
4.9inline6's Avatar
4.9inline6
when i paint my truck, which is a standard cab long bed, i am going to start with a gallon of single stage and then if i need more, ill buy some more...i also am going to be painting my camper top. depending on how many coats you put on, a gallon may be plenty.
chris
Old Jul 10, 2006 | 08:35 PM
beedevil1973's Avatar
beedevil1973
a gallon should be more than enough. most single stages still have to be thinned a little. you are probably going to end up with some left over.
Old Jul 11, 2006 | 08:13 AM
mississauga's Avatar
mississauga
If you remove all of the gloss from the existing paint without breaking through, it should work.
Old Jul 11, 2006 | 10:08 AM
GWall's Avatar
GWall
A gallon should do it with a conventional spray gun. An HVLP can take up to 50% less.
Old Jul 11, 2006 | 11:51 AM
toolfan1's Avatar
toolfan1
I am new to this site and do not want to stir any trouble, but why would you guys want to use single stage paint? Base coat / clear coat is easier to spray in less than perfect conditions and can be fixed easier (wet sanding and buffing). The cost may be a little more but the benefit is far greater. Hope this helps.
Old Jul 11, 2006 | 02:31 PM
mississauga
I guess it depends on what kind of look you want and how much money and time you want to spend.The acrylic enamel paints without metal flake in them can be wet sanded and buffed out with good results. I like the look of base/clear but for certain budget jobs single stage has its place.
Old Jul 11, 2006 | 04:04 PM
4.9inline6's Avatar
4.9inline6
for a decent looking truck that may take a beating every now and then (after all, a truck is a truck) single stage may be the perfect answer.
and yes, single stage w/o the flake can be buffed and it turns out quite purdy.
chris
Old Jan 27, 2007 | 10:47 PM
F250FarmBoy's Avatar
F250FarmBoy
How much will it take to do just the cab? Im getting a flatbed on mine. 3 qts?
Old Jan 28, 2007 | 03:28 AM
ajm859830's Avatar
ajm859830
A primer/sealer is just that, it promotes adhesion yet acts like a sealer and is typically put over etch primer. On the other hand etch primer is used on bare metal its a primer that contains an acid which etches into the metal increasing adhesion. You should be fine w/o primer, if I understand what youre wanting to do correctly you just need to scuff the current finish until there is no gloss and spray over that.
Old Jan 28, 2007 | 03:32 AM
HARLEYEDITION4X4's Avatar
HARLEYEDITION4X4
Barstow, Ca. Ford Camping Trip Feb. 9th-11th 07'
2007 FORD EXTRAVAGANZA
<O:p</O:p
CAMPING TRIP INTINERARY – <O:p></O:p>
<O:p></O:p>
DESTINATION * BELL MOUNTAIN RD, VICTORVILLE, CA<O:p></O:p>
CAMP-SPOT IS A 20 MIN. DRIVE TO THE
CITY<O:p></O:p>
<O:p></O:p>
REASON * START A FUN FORD EVENT. GET OUT OF TOWN,
RELAX & HANG OUT AROUND THE CAMPFIRE<O:p></O:p>
<O:p></O:p>
WHAT TO BRING * A FORD”,FIREWOOD OR CHEVYS
4 THE CAMPFIRE, FOOD, DRINKS,
DIRTBIKE, SANDRAIL,
AND SOMETHING2 SLEEP IN.
<O:p></O:p>
FRIDAY * SET UP CAMP, CAMPFIRE, MEET THE
MEMBERS <O:p></O:p>
(FORD NIGHT CRUISE OPTIONAL)<O:p></O:p>
<O:p></O:p>
SATURDAY * BREAKFAST/COFFEE<O:p></O:p>
SLASH X SALOON CRUISE” BY DIRT ROAD TO
A SALOON/RESTAURANTE LOCATED 30 MIN.
FROM CAMP, IN THE <O:p></O:p>
MIDDLE OF THE DESERT . FACILITIES
INCLUDE POOL TABLES, PLAYGROUND, BAR,
FOOD, TV’S & RESTROOMS. (LUNCH)<O:p></O:p><O:p></O:p>
CRUISE BACK TO CAMP. ( MAYBE STOP BY A
MINE OR 2 ) RELAX A LITTLE MORE. SHOOT
SKEET,TARGETS OR RIDE YOUR TOYS<O:p></O:p>
SAT. AFTERNOON * PHOTO’S OF THE GROUP & TRUCKS
TOGETHER.<O:p></O:p>
GET READY 4 DINNER, CHECK OUT THE
TRUCKS & STARTTHE CAMPFIRE<O:p></O:p>
<O:p></O:p>
SAT. NIGHT * MEMBER MEETING AROUND THE CAMPFIRE TO
DISCUSS CURRENT & UPCOMING TRIPS<O:p></O:p>
<O:p></O:p>
SUNDAY *BREAKFAST/COFFEE. “FORD EXPLORATION <O:p></O:p>
CRUISE” THROUGH THEDESERT. COME BACK &
DO LUNCH. PACK-UP, GET READY TO GO <O:p></O:p>
HOME & PLAN THE NEXT TRIP!<O:p></O:p>
<O:p></O:p>
FOR MORE INFO. REGARDING THE TRIP, PLEASE CONTACT ME (PATRICK) AT (909)-263-2365
Fuzy6525
Apr 15, 2017 01:44 PM
Speedymaru
23
Aug 20, 2016 05:15 PM
Gicknordon
33
Oct 17, 2015 06:23 AM
smokey13
1983 - 2012 Ranger & B-Series
Mar 21, 2014 06:33 PM
Green Streak
Paint & Bodywork
Jan 2, 2007 11:42 AM
