Squeaky Distributor?
Old Jul 7, 2006 | 02:15 PM
go2toa's Avatar
go2toa
Anyone know a cure for a squeaky distributor? Topping off the oil level helps, but doesn't quiet all the way. Maybe I should try "Slick 50".
Old Jul 7, 2006 | 03:00 PM
andym's Avatar
andym
How do you know it's the distributor? I never heard of a squeaky distributor before.
Old Jul 7, 2006 | 10:34 PM
go2toa's Avatar
go2toa
ford dealer in tustin was working on something unrelated and wanted to know what was making that annoying squeak, so they looked into on their own.
Old Jul 7, 2006 | 10:56 PM
mdtodd's Avatar
mdtodd
Never heard of a squaky distributor... let us know what you find out.
Old Jul 8, 2006 | 11:48 AM
go2toa's Avatar
go2toa
If I temporarily remove the serpentine belt and it stops squeaking, we'll know it was probably the water pump bearings going out. We shall see.
Old Jul 8, 2006 | 03:47 PM
alabamabuddog's Avatar
alabamabuddog
An old belt will squeak, I have had to replace my own to stop it in the past.
Old Jul 8, 2006 | 05:48 PM
go2toa's Avatar
go2toa
Wow, it's looking like he was right. The general area that you hear it is near the water pump, yet I started it up with the belt off, and the squeak persisted.
I bet if i replace the distributor it will persist. I suspect it is the gears under the distributor.
Old Jul 8, 2006 | 09:14 PM
BRAWLNBRONC's Avatar
BRAWLNBRONC
before you do that you might want to shoot some wd 30 down into youre distibutor you might have excessive play in the distribotor drive shaft maybe try a dab of oil dont leave any excess though inside the cap the bearings inside the distributor might be needin a little lube Its an idea that might save you some trouble!
Old Aug 12, 2006 | 10:02 PM
go2toa's Avatar
go2toa
the last couple weeks i've aggressively aimed to resolve this. I obtained/installed a new distributor shaft. I changed the oil, made sure it was topped off, included slick 50.
still sqealing, albeit less.
I pulled the shaft and added grease to the gears. That reduced the squealing another 20%. i know it sounds like i'm throwing away good money and too some extent i probably am, but keep in mind, the squeak is just as prevalent with the belt off!
when the engine is hot and idling, it makes no squeak whatsoever. i'm hoping the slick 50 works its way in there and eventually helps. based on what i've researched, the gear drive is less likely to cause this -- people say bushings that the shaft spin in are supposed to be honed to preclude this.
Old Aug 15, 2006 | 01:16 AM
fordtecher's Avatar
fordtecher
the bushing in the dist. is dry or worn replace the dist.
Old Aug 15, 2006 | 11:07 AM
go2toa's Avatar
go2toa
did it last fri
Fmc4lfe
2015 - 2020 F150
Feb 25, 2017 08:57 PM
twinkielk15
16
May 10, 2016 12:21 PM
Mikes150
2009 - 2014 F150
Jul 22, 2015 09:33 AM
wolff7.3
Dec 16, 2013 08:58 AM
Clemzeter
Dec 10, 2004 11:06 AM
