now a squeaky belt
Old Dec 14, 2013 | 06:30 PM
wolff7.3's Avatar
wolff7.3
now a squeaky belt
changed the thermostat and im sure i got coolant and grease on it but it squeakys now. newish belt, tried a dab of belt dressing and made it worse, so i got a wet rag and held it to the belt and pulleys i could get at, and it would quiet down but then would get noisy right after i took the rag off. tried a dab of degreaser on a rag and held it to the pulleys and also made it worse. what the heck is going on with these little irritating annoyances?!
Old Dec 14, 2013 | 07:35 PM
427 fordman's Avatar
427 fordman
Check your tensioner and make sure its ok. Means when you put pressure on the belt wiping it off and the noise goes away, maybe its losing its tension and squeaking, just a thought. I'd check the idler pulley too.
Old Dec 14, 2013 | 08:02 PM
T_F_E's Avatar
T_F_E
If you splash water on it and it gets louder its a tension issue, if it gets quieter its an alignment issue. Assuming your belts alright of course.
Old Dec 14, 2013 | 08:19 PM
wolff7.3's Avatar
wolff7.3
Tensioner seemed tight but ill re do that tomorrow just to be sure also ill check the bottom pulley to see if the belts off the correct grooves
Thanks
Old Dec 14, 2013 | 08:25 PM
wolff7.3's Avatar
wolff7.3
Also fordman67 have you ever dyno'd your pickup to see what that combination makes? It's real close to what I'd like to do eventually
Old Dec 14, 2013 | 09:35 PM
fordman67's Avatar
fordman67
Not yet but when its back together it will.alex made 225ish with intake,exh,ts canned
remove the belt.clean.reinstall backwards.ive seen that help..its worth a shot..
Old Dec 14, 2013 | 10:12 PM
oldbird1965's Avatar
oldbird1965
Or, do the SD tensioner mod.
Old Dec 15, 2013 | 10:18 AM
matts156's Avatar
matts156
Is there a thread already out there for the SD tensioner mod?
Old Dec 15, 2013 | 10:20 AM
fordman67's Avatar
fordman67
There should b. it also was a ford tsb
Old Dec 15, 2013 | 10:44 AM
oldbird1965
http://www.thedieselstop.com/faq/949...les/982314.pdf
Old Dec 16, 2013 | 04:34 AM
matts156's Avatar
matts156
Awesome. Thanks for the link. I definitely plan on doing this mod at some point.
Old Dec 16, 2013 | 08:58 AM
oldbird1965
I also found this one: https://www.ford-trucks.com/forums/1...rade-pics.html
My belt used to wear on the side before this mod, not any more and its easy to do.
JamesHajek
24
Mar 12, 2012 06:55 PM
pipesalesman
Feb 6, 2007 01:28 PM
cmoore99
Jan 29, 2005 09:45 PM
harrym
1983 - 2012 Ranger & B-Series
Nov 2, 2004 07:37 AM
sethro
Jan 15, 2003 01:14 PM
