Anyone Using the Evans Coolant?
Old Jul 6, 2006 | 09:25 PM
dlbuchanan's Avatar
dlbuchanan
I'm getting ready to change the belt, hoses, water pump, T-stat, and coolant on a 99.5 E350. The Evans coolant looks like a good choice for coolant, but before spending all that $$$ I would like to know if anyone else has made the switch and disliked it. Test strips and additives sound like a hassle.
There are no maintenance records on this van (155K miles). I plan to pull maintenance like everything is original stuff.
I will be using the van to haul a 10K+ trailer across country and then puting the van in storage for 6mo - 1yr. Any other suggestions are appreciated.
Thanks,
Don
Old Jul 6, 2006 | 10:40 PM
blessteve's Avatar
blessteve
I have been using Evans for about a year.. No problems.
I switched cause you can do all the SCA crap and your motor can still be destroyed by cavication. No worries with the Evans
Old Jul 7, 2006 | 06:54 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome Don to Ford Truck Enthusiasts!
See you on the boards. ….
Old Jul 7, 2006 | 01:04 PM
cookie88's Avatar
cookie88
FTE Emeritus
I ran it for nearly three years without issue. I liked it a lot, but when I developed a coolant leak the lack of local availability and $20/gallon plus shipping made it too expensive to keep.
There are several locally available coolants you can switch to that do not require any addatives....including the factory coolant the 2002+ Powerstrokes use.
Welcome to the diesel forums.
Old Jul 18, 2006 | 09:17 PM
1nascar24fan's Avatar
1nascar24fan
Question 2002+ coolant?
Wha t kind of coolant does the 2002 have in it ? Does it not require an additive? or sca??? Still confused about this ! thanks for the info. Go 24
Old Jul 18, 2006 | 09:20 PM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
it is hard to say. you have to look on your specific truck. my 2002 has green, and i believe original coolant 9-20-2001.
however i have seen several other guys with a 2002 and original gold coolant.
Old Jul 18, 2006 | 09:26 PM
1nascar24fan
OK, I have the gold but does it not need any additives?
DavenTn
Apr 3, 2014 07:04 PM
SUPERDUTY_WILL
Jan 2, 2011 08:06 PM
rdmytro
Jun 7, 2007 12:55 AM
buddha43
Jul 17, 2005 12:13 PM
Motoxman_117
Mar 16, 2003 12:22 AM
