ww gone bad
Old Jul 17, 2006 | 05:58 PM
05f250fx4's Avatar
05f250fx4
ww gone bad
i just finished everything today, installed ww and hpx from DI. i started her up and i feel less power, new sounds (i dont know if they're good or bad), and the turbo is smokin now. whats wrong with her?
Old Jul 17, 2006 | 07:19 PM
Kwikkordead's Avatar
Kwikkordead
Smoking turbo?????????
Did you pull the turbo or do it on the truck?
Old Jul 17, 2006 | 09:12 PM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
what exactly is "smokin" on the turbo? did you spill any oil or something like that on it?
the new sounds, don't be alarmed. thats the sound of power
Old Jul 17, 2006 | 09:13 PM
05f250fx4's Avatar
05f250fx4
i pulled it. im not exactly sure if its the turbo thats smoking, but the smoke is coming from that general area, maybe the up pipe? but it was smoking when the engine was turned off too
Old Jul 17, 2006 | 09:14 PM
05f250fx4's Avatar
05f250fx4
so to fix the loss of power do i adjust the waste gate?
Old Jul 17, 2006 | 10:52 PM
jtharvey's Avatar
jtharvey
Sounds like some oil may have dripped onto one of the up-pipes. Is the smoke coming out look as if it's being forced out or just kind of rising at it's own pace?
Old Jul 18, 2006 | 07:39 AM
wbhinton's Avatar
wbhinton
cinch up the waste gate (just a little at a time) and do something about your intake (I noticed a considerable difference when I got rid of the stock air box for the 6637) and you should be golden, regarding the power aspect.
I think that the smokin turbo is a result of the WD-40 we sprayed on it to get the exhaust clamps off.
WB
Old Jul 18, 2006 | 09:59 AM
Tenn01PSD350's Avatar
Tenn01PSD350
Check the HPX fittings to make sure it's not spewing oil onto the turbo or housing.
Old Jul 18, 2006 | 11:19 AM
05f250fx4's Avatar
05f250fx4
the smoke is just rising at on its own, no forcing. lemme try degreasing and washing and adjusting the waste gate. which way do i adjust it?
Old Jul 18, 2006 | 12:12 PM
05f250fx4's Avatar
05f250fx4
ok, now theres no more smoke. 1 more problem to fix. will disabling the wastegate help with the power loss? or will i have to take on the tedious task of playing with the waste gate?
Old Jul 18, 2006 | 12:37 PM
edub32's Avatar
edub32
How does the WW add more power?
Old Jul 18, 2006 | 12:59 PM
wbhinton's Avatar
wbhinton
there was a thread that discussed waste gates and WW and boost recently.... lemme find the link
Old Jul 18, 2006 | 01:01 PM
05f250fx4's Avatar
05f250fx4
it doesnt. the thing is, its not supposed to take away power. the whole point of it is to eliminate turbo surge. side effects should include louder turbo whistle.
Old Jul 18, 2006 | 01:03 PM
wbhinton's Avatar
wbhinton
Read these two posts about waste gates and WW
Description of what disabling the wastegate does:
https://www.ford-trucks.com/forums/s...d.php?t=508125
Discussion on disabling the wastegate:
https://www.ford-trucks.com/forums/s...d.php?t=505914
Old Jul 18, 2006 | 07:42 PM
05f250fx4's Avatar
05f250fx4
i've disabled the waste gate and power is still lacking. i suppose i'll have to adjust the rod
