Evans coolant questions
Old Jul 13, 2005 | 11:08 PM
buddha43's Avatar
buddha43
Anyone who has done the switch to Evans coolant, after it has been in the motor for a week or so, does it change color? When I put it in it was clear, now it looks kinda brownish. Is this normal?
Eric
Old Jul 14, 2005 | 08:37 AM
bigdaddyTank's Avatar
bigdaddyTank
That is probably from all the sand and grit in the cooling system. The diesel's have alot of casting sand and material in the block, its one of the reasons I added a coolant filter.
Old Jul 14, 2005 | 03:21 PM
buddha43's Avatar
buddha43
I was thinking that too, but wasn't sure. But, I did add a coolant filter at the same time, so hopefully it will clear all the crap out over time.
Old Jul 17, 2005 | 04:18 AM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
I wouldn't go more than a couple of weeks on the first filter. Then change the second one after a couple of months. After that just make it annual maintenance.
The Evans will never clear up. It will be dark brown pretty soon and stay that way.
Old Jul 17, 2005 | 12:06 PM
Steve_250's Avatar
Steve_250
Any easy way to see if the filter is dirty without cutting it open?
I know the cast sand is too small to see but maybe it discolors the element?
Old Jul 17, 2005 | 12:13 PM
buddha43's Avatar
buddha43
Thanks Cookie....that is exactly what I have planned on doing. I have been checking the coolant filter, and after 1 week, it is still staying hot, so I know coolant is still flowing thru it. I am prolly going to change it next week anyway.
As far as the color, knowing that it turns brown and stays brown satisfies my original question. When I opened the hood and saw it had turned brown, I kinda wondered if I had screwed something up.....now I know that at least I didn't screw that up.....
Encho
1978 - 1996 Big Bronco
Jan 30, 2013 01:58 AM
rdmytro
Jun 7, 2007 12:55 AM
dlbuchanan
Jul 18, 2006 09:26 PM
Motoxman_117
Mar 16, 2003 12:22 AM
evans
Dec 14, 2001 04:21 PM
