I have a 1991 F-150 Supercab, and im looking to see if the extended cab glass can be swapped for that in the '92-'96 trucks. The opening seems to be the same size, I am just not sure if the glass, molding, etc. will bolt in correctly. Has anyone tried this?
i was thinking about doing the same thing to my 87 super cab, i have heard of this being done before but i'm not sure if the window bolted up or if there had to be modifications done
anyone here know of this happening before, is it worth it. I have noticed that the plastic on the inside that goes around the window will have to be replaced with one from a truck without the bar in the middle of the window
I thought that the 87-91 cabs were different in that you got a double window instead of a single window for the extended cab area....my dads 88 F-250 was that way...
