4.6 into older truck
#32
-sb31
would you mind sending me an email..
i got a couple of questions
dls_eddie@yahoo.com
thanks
eddie
dls_eddie@yahoo.com
thanks
eddie
#33
wow. that truck is going to be a head turner. i have a 64 stepside that would look sweet with that setup. what years and models will work for this and how much will the stance of the truck change. wil i still be able to pro street if i decide to or is this swap more intended for cruising.thanks bentts64
#34
Cool stuff guys - I'd love to be around those swaps just to learn what all to consider. But I have a question, too - why move to computer-reliant motors as opposed to swapping in motors that can stand alone?
The 4.6 is a great platform that, with occasional hiccups, will go a good many miles, but in the future will all the computers and modules be available as they wear out? Was this a consideration at all?
#35
#36
Parts getting worn out is inevitable. EFI or Carbed. With a little research, going to a stand alone EFI is very possilbe ( I havnt got this far, but am very close) Ill be using the Megasquirt system.
I guess really it will come down the replacement cost. How much to rebuild an older motor that is good to say 100K. Where as a modern motor is good to 200K. I know older motors have gone over that, but back when they were put out, were they really thought to go past 100K?? I dont think so.
Keeping that in mind, what modern motor can you swap in that can be found at a yard? On the flip side with the older motor, where can you find a good replacement or shop to rebuild it? You could easily be into a rebuilt older motor for the cost of 2 junk yard modern motors. 1 will get you to 100K and youll get 400K from the other 2.
Its late, but I thought I would throw that food for thought out there.
#38
#40
Wow it has really been a while since I posted here. Not much has changed in my project. On my project for those that need a quick recap, I put a 2005 Grand Marquis 4.6 2 valve in my 68 f-100 along with the front end suspension from that vehicle. Unlike 72 I am attempting to use all the original wiring and computer so that means I will have to use the original sending unit from the vehicle. I was for the longest time searching for a way to use the stock Grand Marquis sending unit with a custom tank without paying for a custom tank. Too expensive. I think I found an alternative and that is using a basic fuel cell, aluminum, and then making the simple alterations to fit the larger sending unit from the 2005 Grand Marquis. I will be hopefully this summer running fuel lines from the tank, if it works, up to the motor and seeing if I can get ignition. I still have to make a simple bracket for the fuel cell to make it bolt up to the frame. I was not able to use the 72 mustang tank like others have talked about since I was going to use the stock sending unit. I would have had to still alter the 72 tank. If this all works out then I will be posting pictures and hopefully show some progress.
I just realized you were probably talking about another project.
SS
SS
