will a 78 302 replace a 86 351 with no problems?
Old Mar 20, 2010 | 08:16 AM
aricanderson's Avatar
aricanderson
Ok i had a blown 351 in a 86 f250. Now i found another engine and i was wonderin if the power steering and ac brackets will work. Its a 78 302. Are all the accessory mounting brackets still the same on the two engines?
Old Mar 20, 2010 | 09:26 AM
Conanski's Avatar
Conanski
No the accessory brackets are different because the 351 is physically taller and wider.
Old Mar 20, 2010 | 09:32 AM
aricanderson
if i get the acc brackets for the 302 will they fit the ac, power, and alt stuff that i have. or is there a way to modify the brackets that i have to make it work
Old Mar 20, 2010 | 11:15 AM
Conanski's Avatar
Conanski
Yes.. brackets for a 302 truck from the mid 80's will accept all your existing accessories. FYI.. The brackets on the EFI trucks fit both motors because there is a pair of holes where they mount to the timing cover that accounts for the extra width of the 351 block, but I'm not sure if the older brackets are the same. I'm just mentioning this and I'm not suggesting you use these newer brackets because those motors also use a single serpentine belt for everything and the front-back offset is most likely different as is the mounting points for the accessories. My point was to suggest you look at the brackets you have to see if they have this provision, and if not you definitely need 302 brackets.
And just be aware that this 302 is going to be really weak compared to the 351 you had.. particularly if you had the 351HO with the 4bbl. If it's just to get the truck operational and you're not doing any heavy hauling you'll be OK but if not there are a few things you can do to really wake the motor up that won't cost much like swap on some E7TE heads off an '87 or later motor and install a better cam like the Comp XE250H(Grind #35-230-3). This '78 is a smog era motor with low compression and a puny cam that produced about 150hp, the changes I mentioned fixes both issues and bring it up to a more respecatble 250hp territory.
Old Mar 20, 2010 | 08:40 PM
aricanderson
Looks like the brackets maybe a little different, the alt bracket is different, the power steering is just a lil different, i'll try to use the power steering from the 302 to see if it will match up with my power steering pump. Then ac i'll worry about later. Yes I'm just trying to get the truck running because its been sitting for so long and has never run right yet. So its time to get it going. Although else looks like it will work. Its still the 6 bolt bellhousing, the exhaust manifolds match, the distributor plugs looks like it may work. I also got the 302 flywheel and motor mounts. As long as my alternator bolts up and the power steering i'll be good. I'll let u know how it goes.
Old Mar 20, 2010 | 09:12 PM
Conanski's Avatar
Conanski
Both motors use the same motor mounts.
And the 302 switched from a 28oz balance to 50oz in 1981, while the 351 has always been 28oz. That means you can reuse the flywheel or flexplate from the 351 if it's in good shape.
Old Mar 22, 2010 | 08:17 PM
aricanderson
one more question what about the bracket for the throttle cable. Where does that bolt on to the intake manifold? and Will my throttle cable work?
Old Mar 23, 2010 | 10:09 AM
Conanski's Avatar
Conanski
I don't know about the throttle brackets for these motors but there's no reason to suspect it won't bolt on just fine since Ford has used the same carbs for a long time.
Old Mar 24, 2010 | 05:56 AM
kaboom10's Avatar
kaboom10
Subscribing.
Old Mar 26, 2010 | 09:30 PM
aricanderson
Heres a side pic of the new engine
Top of engine
Exhaust manifold being painted
Old Mar 26, 2010 | 09:33 PM
aricanderson
I cleaned and repainted the 351 alternator bottom bracket which i believe i can use with a 6in bolt in the top and make the alternator work.
Old Mar 26, 2010 | 09:56 PM
aricanderson
what size carb should i get? should i stick with a 600 cfm 4 barrel?
Old Mar 26, 2010 | 09:58 PM
Conanski's Avatar
Conanski
That's plenty of carb for either motor.
Old Mar 27, 2010 | 07:52 PM
aricanderson
Exhaust manifold installed with new bolts.
One thing i noticed is that the water pump pulley does not exactly line up with the crankshaft pulley. Weird. I guess thats another thing i will have to remedy. Maybe some washers will put the pulley back in alignment.
7379ford
Engine Swaps
Aug 2, 2017 01:51 AM
Sam's1967
Dec 5, 2016 04:09 PM
ftwosh
1978 - 1996 Big Bronco
Feb 28, 2011 09:44 PM
BlackJacJL
Dec 22, 2004 09:29 PM
cbwarrior
Jul 3, 2000 04:03 AM
