engine swap 4.6l DOHC to a 2000 f150 4.6l sohc
Get your DOHC year correct.
None in an 85 Mustang. There are all push rod motors back then.
OHC did not appear until about 1990 in the bigger cars and a little later in the Mark 8 1993.
You will need to have the ECM and harness that uses the coils and plug wire setup.
Look at a later Lincoln Navigator setup that will be closer to what you need.
The Lincoln motors have already been put in the F150 as a swap.
Good luck.
Good luck.
