p/s plumbing
Old May 27, 2000 | 04:23 AM
red68ranger's Avatar
red68ranger
p/s plumbing
I know I asked once before but I have to confess I forgot. Which is the high side and which is the return port on the p/s gear box? I'm assuming the tube out the center of my pump is the high side there since it has the compression fittings on it. I got the old column and box out last night after work and am putting in the new this morning. I hope to be plumbing it up in a few hours. Thanks in advance,
Dan Blackwell
Old May 27, 2000 | 04:30 AM
jowilker's Avatar
jowilker
p/s plumbing
Dan check your fittings, They are different sizes for NO cross overs.
John
jowilker
66 F100s
In the still cool hours of the night, you can hear chevys rusting away.
Old May 27, 2000 | 10:44 AM
red68ranger
p/s plumbing
Thanks, I found that right after I posted this a.m. Unfortunately it didn't count for much. The gearbox I was sold has a part # that starts D9.... It hits my engine perch. There must be something changed in '77 when the FE's were discontinued that makes the '79 gearbox incompatible with the '68 FE's perch. It's close, but I can only get one bolt in. The other two miss by about 1/4". Got all the manual stuff back in til I can get another gearbox.
DB
>overs.
>John
>jowilker
Old May 27, 2000 | 11:18 AM
jowilker's Avatar
jowilker
p/s plumbing
Easy Big Dan not to despair, You need a left perch from a 360 with power steering. It is angled forward and the top moves up one set of holes, then the gear will fit just fine. All of the gears as the same from 65 to 79.
I have also heard of grinding a notch in the perch to except the gear. Your call.
John
jowilker
66 F100s
Old Jun 2, 2000 | 11:37 AM
red68ranger
p/s plumbing
>as the same from 65
>to 79.
Mr. John,
I was about to decide you were sending me after a part that they kept next to the chrome muffler bearings when, lo and behold, I found it. Four different yards and dealers all said they never heard of it. The dealer even looked thru the Ford parts book and couldn't find where there was a different perch for an FE pulling p/s. Then I drove out and checked on the truck I got my tranny out of and presto, angled forward, mounted in different holes, a little lower profile on the ridge, there it was. Now I just gotta go pick up the 800# chunk of iron sitting on top of it and I can take it home.
Thanks fellow,
DB
p.s. The day job had me in Cary yesterday. How close was I?
Old Jun 2, 2000 | 02:58 PM
jowilker's Avatar
jowilker
p/s plumbing
20-25 min. Dang and you coulda bought me lunch, Where were you?
I try, I don't keep a bunch of refference books like Stockman, but he has a degree, I had to use one with my truck to make it work.
Glad I could help.
John
jowilker
66 F100s
Old Jun 2, 2000 | 06:28 PM
red68ranger
p/s plumbing
>you?
>make it work.
>Glad I could help.
>John
Got the perch. It was a snap--'course the truck it came from didn't have an engine. Putting it in my truck looks like it'll be the hardest part of the p/s conversion. These were some hard to get at bolts with both I-beams running right below 'em.
I was on Sheldon Drive, at a place that makes tank level gauges for jet fuel storage tanks. It looked like a newly developed area, real nice. Probably be up at Bragg/Pope for a week or so within the next few months. I may drive on up if I get a chance.
DB
Old Jun 2, 2000 | 08:55 PM
jowilker's Avatar
jowilker
p/s plumbing
You were up near the airport, more like Morrisville. Everything is new in that area, a lot of growth there.
John
jowilker
66 F100s
Old Jun 3, 2000 | 05:12 AM
jowilker's Avatar
jowilker
p/s plumbing
Scott Blackwell
Jul 9, 2006 09:53 PM
red68ranger
Jun 28, 2000 07:42 PM
red68ranger
May 26, 2000 01:25 AM
red68ranger
May 10, 2000 09:31 AM
red68ranger
Apr 24, 2000 06:55 PM
